Similarities of negative absolute temperature to dark energy?
In summary: In fact, they're pretty terrible. One of the problems is that they're unstable: if you take an object out of a negative temperature state and put it into a positive temperature state, it will quickly start to thermalize, or warm up, back to the normal temperature.In summary, Ulrich Schneider explains that the gas in the experiment is hotter than it is at any positive temperature, and that it is even hotter than at any negative temperature. This is what has been achieved, and it is a hallmark of negative absolute temperature.
julcab12
331
28
“The inverted Boltzmann distribution is the hallmark of negative absolute temperature; and this is what we have achieved,” says Ulrich Schneider. “Yet the gas is not colder than zero kelvin, but hotter,” as the physicist explains: “It is even hotter than at any positive temperature – the temperature scale simply does not end at infinity, but jumps to negative values instead.”
1.Does it imply that we can break the stable coherent state of an atom and render it motionless. What does it say about +- excited state of an atom. 2. How about the condition of our universe. Any thoughts?
http://www.quantum-munich.de/fileadmin/media/media/Negative_Temperature/Negative_absolute_Temperatur-EN-3.1.13.pdf
http://www.sciencedaily.com/releases/2013/01/130104143516.htm
Space news on Phys.org
What do you mean with "motionless"? Cool a gas until most atoms are in the ground state? That is possible, and the result is a Bose-Einstein-condensate.
Remove everything which could be considered kinetic energy? That is not possible.
I don't see any relation.
And I don't see the relation to dark energy.
I'm not a physicist. Just an avid reader. It's a bit misleading sometimes when they mention of 'At zero Kelvin (-
460°F or -273°C) the particles stop moving and all disorder disappears. Thus, nothing
can be colder than absolute zero on the Kelvin scale.'
From what i know and read; atom is not totally motionless i.e particles position and momentum are not dependent of each other(HUP doesn't allow it). When they mention stop moving, do all particles in the system be completely at rest in their positions means that they will have a definite position and a definite momentum (ie zero)? Which is highly unlikely.
They always mention dark energy resembling the same effect(thermodynamic behavior of negative temperature) each time I've read that subject on the net. "the atoms in the gas do not repel each other as in a usual gas, but instead interact attractively. This means that the atoms exert a negative instead of a positive pressure. As a consequence, the atom cloud wants to contract and should really collapse – just as would be expected for the universe under the effect of gravity. But because of its negative temperature this does not happen. The gas is saved from collapse just like the universe."
0K (as coldest temperature) corresponds to everything in its ground state. Due to quantum mechanics (related to the uncertainty principle), the energy is above the ground state we would have in classical mechanics. This difference can be interpreted as potential and kinetic energy - even if the system is perfectly static, so the wave function (describing the particle) does not move.
Dark energy is not a gas.
When you have a very special sort of quantum system that has a maximum possible energy, then and only then can you have negative temperatures.
This comes about because if you have a maximum possible energy, then the entropy of that state necessarily has very low entropy. And systems tend to avoid low-entropy configurations. How do you increase the entropy of a maximum-energy state? You reduce its energy. So the moment you bring this system into contact with some other system that is at a normal temperature, it loses energy to the other system, no matter what the temperature of this other system is.
This means a few things:
1. The idea of cooling an object below absolute zero is nonsense: temperatures below absolute zero are hotter than any positive temperature.
2. You also can't heat an object to negative temperatures: anything you use to try to heat it will only be at some positive temperature. This means that you have to sort of "trick" the system, for example by changing the energy states available so that what was a positive-temperature state becomes a negative temperature state.
3. Negative temperature states generally won't last very long: you can't keep them completely out of contact with other matter, so they will tend to lose energy quite rapidly until they come into equilibrium with their surroundings. But they may, in some cases, last long enough to be measured.
... Neither did we know 'if' it has any or so 'physical property' (signs maybe 'assuming a dark energy as fluid having jeans mass) to it(limited to methodology of effects). In some sense both resembles the same effect or the best, the closest we have as a physical effect. If you want to put it that way. Bit far fetch but Interesting nonetheless.
Oh.. Now it makes more sense. Thanks for pointing out some of my missing info's!
Related to Similarities of negative absolute temperature to dark energy?
1. What is negative absolute temperature?
Negative absolute temperature is a concept in thermodynamics where the temperature of a system can be below absolute zero (-273.15 degrees Celsius). This means that the particles in the system have more energy at lower temperatures than at higher temperatures, which is opposite of what we observe in our everyday lives.
2. How is negative absolute temperature similar to dark energy?
Negative absolute temperature and dark energy are similar in that they both involve a state of energy that is counterintuitive and goes against our understanding of traditional thermodynamics. In both cases, the systems have more energy at lower temperatures or densities, which goes against the natural tendency for energy to spread out and decrease.
3. What are some real world examples of negative absolute temperature?
One example of negative absolute temperature is a group of atoms in a laser trap, where they are trapped in a specific energy state and their temperature can be measured as negative. Additionally, some supercooled gases can exhibit characteristics of negative absolute temperature.
4. How is negative absolute temperature measured?
Negative absolute temperature can be measured using techniques such as laser cooling and trapping, which involves using lasers to cool and trap atoms in a specific state. Measurements can also be taken using spectroscopy techniques to observe the energy levels and temperature of the system.
5. What are the potential implications of the similarities between negative absolute temperature and dark energy?
The similarities between negative absolute temperature and dark energy could provide insights into our understanding of the universe and could potentially lead to new technological advancements. It could also help us better understand the behavior of matter at extreme temperatures and densities, such as those found in black holes.
