Simple Coefficient of Friction Question
In summary, the correct answer to the first part of the homework is 1.62 and not 0.62. The correct answer to the second part of the homework is that the COF changes everytime a different force is applied.
ahsanxr
350
A ring on a rod of weight 8 N. A 7 N force at an angle of 45 degrees to the rod is acting away from the ring. The system is in limiting equilibrium. Find the coefficent of friction between the rod and the ring.
Quite obvious.
Could someone explain to me as to why the correct solution is 1.62 and not 0.62? If the former is the case doesn't the COF change everytime a different force is applied?
May we have a picture please? Or a better description of the problem? 1.6 is an unusually high friction coefficient, which is independent of the loading. But I don't understand the problem.
A ring of weight 8 Newtons is threaded on a rod. An external force of 7 Newtons is acting at an angle of 45 degrees from the horizontal on the ring and is trying to pull it to the right. The system is in limiting equilibrium. The first part asks us to show that the normal contact force exerted by the rod on the ring is 3.05 N which can easily be found by subtracting the vertical component (7sin45) of the external force from the weight (8 N). Then in the next part it asks us to find the COF.
My solution was to first find the maximum value of Friction by equating the Horizontal component of the external force (7cos45) with friction since the system is in limiting equilibrium. The problem comes when using F = mew x R. I used the R when an external force is not being applied (8 N) and divided 7cos45 by it to find 0.62. But most other people who took the exam divided it by the R found in the previous part (3.05) to find 1.62 as the COF. I want to know which method is correct and why.
At limiting equilibrium, the ring is just on the verge of moving, so the static friction force must equal the horizontal component of the applied force, and be at its maximum value, F_f = uN, where N is the normal contact force between the rod and ring. So if F_f = 7 cos 45, and N = 3.05, then u= 1.6 . You can't use N = 8 if N is actually 3.05.
Ohhhh I get it now. So when calculating Mu, we always take the value of N when the system is in limiting equilibrium. Is that correct?
Yes. For objects in equilibrium, the static friction force, F_f, is always less than or equal to u_s(N). At limiting equilibrium, it is exactlty equal to u_s(N). u_s is the coefficient of static friction which is a function of the surfaces of the materials in contact only. N is always the normal force.
Ok thanks. That clears up a lot.
FAQ: Simple Coefficient of Friction Question
What is the simple coefficient of friction?
The simple coefficient of friction is a measure of the amount of resistance between two surfaces in contact with each other. It is a dimensionless quantity and is represented by the symbol "μ".
How is the simple coefficient of friction calculated?
The simple coefficient of friction can be calculated by dividing the force required to move an object over a surface by the weight of the object. This can be represented by the equation μ = F/W, where μ is the coefficient of friction, F is the force, and W is the weight.
What factors can affect the simple coefficient of friction?
The simple coefficient of friction can be affected by various factors such as the nature of the surfaces in contact, the roughness of the surfaces, the weight of the object, and the presence of any lubricants or contaminants on the surfaces.
What are the units of the simple coefficient of friction?
The simple coefficient of friction is a dimensionless quantity and therefore has no units. It is represented by the symbol "μ".
Why is the simple coefficient of friction important?
The simple coefficient of friction is important because it helps us understand and predict the amount of resistance between two surfaces in contact with each other. This is crucial in various fields such as engineering, physics, and materials science, where reducing friction can improve efficiency and performance of systems.
