Simple Conic I am sure - Overlooking it
  • Thread starter chrisdapos
In summary, the conversation is about finding the graph of 4x^2 + 9y^2=1, with the hint to use the identity 4x^{2}=(\frac{x}{\frac{1}{2}})^{2}. The problem is solved by realizing that the equation is of an ellipse with center at the origin and using the standard form (x^2)/(a^2) + (y^2)/(b^2) = 1 to find the values of a and b, which represent the vertical and horizontal lengths of the ellipse. The conversation also discusses the purpose of A and B in the standard form equation.
chrisdapos
23
Graph 4x^2 + 9y^2=1
I have no idea where to start. There is nothing to divide out by, and there are no A or B terms. Any assistance is greatly appriciated!
Thanks,
Chris
Hint: what would you get with x^2 + y^2 = 1? Different equation, same idea.
A circle with radius 1. So does this mean I get an ellipse, centered at the origin with a=2 and b=3?
Hint:
Make use of the identity
[tex]4x^{2}=(\frac{x}{\frac{1}{2}})^{2}[/tex]
chrisdapos said:
Graph 4x^2 + 9y^2=1
Thanks,
Chris
It is an ellipse with center at the origin. Do you know how to use the standard form of the equation of an ellipse to find the vertical and horizontal lengths of the ellipse? Intermediate Algebra; standard form for untranslated ellipse is:
(x^2)/(a^) + (y^2)/(b^2) = 1;
What do the "a" and the "b" tell you?
A and B tell you the distance from the center of the ellipse to make a point. A tells you how far in the verticle direction (up and down) to move, and B tells horizontal direction to move (left and right). I don't understand this however becuase there are no A and B, unless both are 1. I don't know why I am getting so hung up on this problem, I did all my other conics fine.
Excuse me for omitting one of the symbols in the standard ellipse equation. I meant to write: (x^2)/(a^2) + (y^2)/(b^2) = 1
Rewrite the 4 so that you have x^2/something. Do the same thing with the 3
FAQ: Simple Conic I am sure - Overlooking it
What is a simple conic?
A simple conic is a type of geometric shape that can be created by intersecting a cone with a plane. Examples of simple conics include circles, ellipses, parabolas, and hyperbolas.
How is a simple conic formed?
A simple conic is formed when a plane intersects a cone at various angles. The specific angle of intersection will determine the type of simple conic that is created.
What is the difference between a circle and an ellipse?
A circle is a type of simple conic in which the plane intersects the cone at a 90-degree angle, resulting in a shape with a constant radius. An ellipse is a type of simple conic in which the plane intersects the cone at an angle greater than 0 degrees but less than 90 degrees, resulting in a shape with varying radii.
What are some real-world applications of simple conics?
Simple conics have many practical applications in fields such as engineering, architecture, and physics. For example, parabolic reflectors are used in satellite dishes to collect and focus signals, and hyperbolas are used in antenna design for radio transmission.
Why is it important to understand simple conics?
Understanding simple conics is important because they are fundamental geometric shapes that are used in many mathematical and scientific applications. They also have real-world applications that can be seen in everyday life, making them relevant and useful to know.
