Simple-Connectedness in Complex Plane: Def. in Terms of Riemann Sphere.
In summary, the definition of simple-connectedness for a region R in the complex plane C states that R is simply-connected if the complement of R on the Riemann Sphere is connected. However, when considering the image of R under the stereo projection h and defining connectedness using the topology of the 1-pt compactification of the plane, it is not clear whether the image contains the point-at-infinity. In the case of a strip, its image in the sphere is connected if it includes the north pole N, but not otherwise. It is unclear what to do in this scenario.
WWGD
11,168
Hello,
There is a definition of simple-connectedness for a region R of the complex plane C that
states that a region R is simply-connected in C if the complement of the region in the
Riemann Sphere is connected. I don't know if I'm missing something; I guess we are actually consider the image of R under the stereo. projection,h, and defining connectedness using the topology of the 1-pt compactification of the plane. But it is not clear whether the image contains the point-at-infinity. So, say we have a strip S:=a< Imz <b , where Imz is the imaginary part of z. Then its image in the sphere would be a vertical strip going through the north pole N; but it seems like the image h(S) is connected if h(S) contains N, but not otherwise. So, what do we then do?
WWGD said:
Hello,
The com[plement of a strip in the complex plane is two regions, the domains above and below the strip. This is not conected. But on the Riemann sphere they are joined at the north pole. This is connected.
FAQ: Simple-Connectedness in Complex Plane: Def. in Terms of Riemann Sphere.
1. What is simple-connectedness in the complex plane?
Simple-connectedness in the complex plane refers to the property of a region in the complex plane being connected and containing no holes or gaps. This means that any closed loop within the region can be continuously deformed into a single point without leaving the region.
2. How is simple-connectedness defined in terms of the Riemann sphere?
In terms of the Riemann sphere, simple-connectedness can be defined as the region being topologically equivalent to a disc or a sphere. This means that the region is simply connected if it can be continuously deformed into a disc or a sphere without any holes or gaps.
3. What is the relationship between simple-connectedness and the fundamental theorem of algebra?
The fundamental theorem of algebra states that any non-constant polynomial with complex coefficients has at least one root in the complex plane. Simple-connectedness in the complex plane is closely related to this theorem as it guarantees the existence of a continuous path from any point in the region to the root of the polynomial, allowing us to use Cauchy's integral formula to evaluate the integral of the polynomial over the region.
4. Can a region in the complex plane be simple-connected and multiply-connected at the same time?
No, a region in the complex plane cannot be both simple-connected and multiply-connected at the same time. Simple-connectedness implies the absence of any holes or gaps in the region, while multiply-connectedness implies the existence of at least one hole or gap in the region.
5. How does simple-connectedness in the complex plane relate to the concept of homotopy?
Simple-connectedness in the complex plane is a special case of the concept of homotopy. A region in the complex plane is simply connected if and only if any two continuous paths between two points in the region can be continuously deformed into each other without leaving the region. This is the definition of homotopy in topology.
