Simple constant acceleration/equation of motion question
In summary, the time to reach the end of the runway for a 747 jet is 34.4 seconds and the jet needs an acceleration of 1.17 meters per second squared to fly over the shorter runway. This is probably not feasible, as the average speed for a 747 jet when accelerating is only around 250 kilometers per hour.
Touran Khan
A 747 Jumbo Jet must reach a speed of 290km/h by the end of the runway to lift off. The 15L-33R runway at Toronto International Airport is 2,770 meters long. The main Toronto Island Airport runway 08-26 is 1216 meters long. Assuming the jet has a constant acceleration, for each runway:
a) Determine the time to reach the end of the runway
b) Determine the required acceleration.
c) Do you think 747’s will ever take off and land on the island? Explain in 3 or 4 lines
t = d/s
v = u + at
v^2 = u^2 + 2ax
where u = initial velocity, x = displacement
a) 290 km/h = 80.5 m/s
Runway A)
t = 2770/80.5
= 34.4 s
Runway B)
t = 1216/80.5
= 15.1 s
b) Can I assume initial velocity to be 0 and then just use the formulas? Can I also just use the constant acceleration formulas to calculate time for part a)? Because when I do try that and input initial velocity as 0, then the values I get for time are exactly two times the values I got in part a) using t = d/s. Why is this the case?
Thanks a lot.
Because when you use t = d/s you are assuming a constant speed. But that's not the case. (Hint: What's the average speed of the jet as it accelerates?)
Ah, I see. In that case,
Runway A)
x = 2770 m
u = 0 m/s
v = 290 km/h = 80.5 m/s
v^2 = u^2 + 2as
80.5^2 = 0 + 2a(2770)
a = 1.17 m/s^2
Calculating t:
v = u + at
80.5 = 0 + (1.17)(t)
t = 68.8 s
this is my revised solution. Would this method suffice?
Sure.
But it might even be easier to use d = vavet to find the time. Then v = at to find the acceleration. But your way is fine too!
Likes Touran Khan
Doc Al said:
Sure.
Actually, just took another look at this. Would you mind explaining how you'd use your method to do this? Particularly d = vavet. I feel like that's the same as 2770 meters/250 km/h, no? As that is what I did initially (albeit using scalar quantities, t = d/s) but that was under the incorrect assumption that speed was constant.
Thanks a lot!
Thanks a lot!
First, the time for a journey is distance/average speed. So, if you know any two of distance, time and average speed, you can simply calculated the one you don't know.
Second, for constant acceleration, the average speed is half way between the initial speed and the final speed. So, if you start at 10m/s and constantly accelerate to 30m/s, then your average speed during this time is 20m/s.
In particular, if you accelerate from rest, then the average speed is half the final speed.
Note: you used the final speed in your calculation (which is clearly not right) and @Doc Al used the average speed.
I think @PeroK did a great job explaining how average velocity is used. Let us know if anything is unclear.
Related to Simple constant acceleration/equation of motion question
1. What is the equation of motion for an object with constant acceleration?
The equation of motion for an object with constant acceleration is v = u + at, where v is the final velocity, u is the initial velocity, a is the acceleration, and t is the time.
2. How do you calculate the displacement of an object with constant acceleration?
The displacement of an object with constant acceleration can be calculated using the equation s = ut + 1/2at^2, where s is the displacement, u is the initial velocity, a is the acceleration, and t is the time.
3. Can the equation of motion be used for both linear and circular motion?
Yes, the equation of motion can be used for both linear and circular motion as long as the acceleration is constant. For circular motion, the acceleration is directed towards the center of the circle, and the equation can be modified to include the radius of the circle.
4. How does the acceleration affect the motion of an object?
The acceleration of an object determines how quickly the object changes its velocity. A larger acceleration will cause the object to change its velocity more quickly, resulting in a faster motion. On the other hand, a smaller acceleration will result in a slower motion.
5. What is the difference between constant acceleration and uniform motion?
Constant acceleration refers to a situation where the acceleration of an object remains the same throughout its motion. On the other hand, uniform motion refers to a situation where the velocity of an object remains constant. In uniform motion, the acceleration is equal to zero, while in constant acceleration, the acceleration is non-zero and remains constant.
