Simple (Constant) Wavefunction -- Find Uncertainty In p^2
In summary, the conversation involved finding the uncertainty in the momentum and the uncertainty product for a given wave function valid over a specific range. The wave function was written in terms of Heaviside functions and its derivative was used to calculate the expectation value of momentum. However, a mistake was made in the calculation due to the integration of a Dirac delta function and the Heaviside step function. Alternative approaches, such as taking the Fourier transform of the wave function, were suggested but may also run into problems when trying to compute the expectation value of momentum squared. Qualitatively, it was suggested to estimate the uncertainty in momentum by taking the width of the central lobe of the wave function in momentum space.
loginorsinup
54
Given the following wave function valid over [itex]-a \le x \le a[/itex] and which is 0 elsewhere,
[tex]\psi(x) = 1/\sqrt{2a}[/tex]
Find the uncertainty in [itex]\left<\left(\Delta p\right)^2\right>[/itex] momentum, and the uncertainty product [itex]\left<\left(\Delta x\right)^2\right>\left<\left(\Delta p\right)^2\right>[/itex]
Expectation value of an observable [itex]\underline{\alpha}[/itex]
[tex]\left<\alpha\right> = \int_{-\infty}^{\infty} \psi^*\alpha\psi\; dx[/tex]
Heaviside / unit step function
[tex]H(x) = \begin{cases}1, x\ge 0\\0, \mathrm{otherwise}\end{cases}[/tex]
Relationship between Heaviside and Dirac delta function
[tex]\delta(x) = \frac{dH(x)}{dx}[/tex]
Uncertainty of an observable [itex]\underline{\alpha}[/itex]
[tex]\begin{align*}
\left<\left(\Delta\alpha\right)^2\right> &= \left<\left(\alpha -
\left<\alpha\right>\right)^2\right>\\
&= \left<\alpha^2\right> - \left<\alpha\right>^2
\end{align*}[/tex]
To find the uncertainty in momentum, which is just the difference between the expectation value of the square of momentum and the expectation value of the momentum, I need to find [itex]\left<p\right>[/itex] and [itex]\left<p^2\right>[/itex]
First, the wave function and its conjugate can be written in terms of Heaviside functions.
[tex]\begin{align*}\psi(x) &= \frac{1}{\sqrt{2a}}\left[H(x+a)-H(x-a)\right]\\\psi^*(x) &= \frac{1}{\sqrt{2a}}\left[H(x+a)-H(x-a)\right]\end{align*}[/tex]
Next, [itex]\left<p\right>[/itex]
[tex]\left<p\right> = \int_{-\infty}^{\infty} \psi^*(x)\left[\frac{\hbar}{i}\frac{d}{dx}\right]\psi(x)\; dx[/tex]
The derivative of [itex]\psi(x)[/itex] is
[tex]\begin{align*}\frac{d\psi(x)}{dx} &= \frac{d}{dx}\left(\frac{1}{\sqrt{2a}}\left[H(x+a)-H(x-a)\right]\right)\\
&= \frac{1}{\sqrt{2a}}\left[\delta(x+a)-\delta(x-a)\right]\end{align*}[/tex]
So, [itex]\left<p\right>[/itex] is
[tex]\begin{align*}\left<p\right> &= \int_{-\infty}^{\infty} \psi^*(x)\left[\frac{\hbar}{i}\frac{d}{dx}\right]\psi(x)\; dx\\
&= \int_{-\infty}^{\infty} \frac{1}{\sqrt{2a}}\left[H(x+a)-H(x-a)\right]\frac{\hbar}{i} \frac{1}{\sqrt{2a}}\left[\delta(x+a)-\delta(x-a)\right]\; dx\\
&= \frac{\hbar}{i2a}\int_{-\infty}^{\infty} \left[H(x+a)-H(x-a)\right]\left[\delta(x+a)-\delta(x-a)\right]\; dx\end{align*}[/tex]
Distributing out results (FOILing), in all but the [itex]H(x-a)\delta(x+a)[/itex] integrand component producing 1. The [itex]H(x-a)\delta(x+a)[/itex] part produces 0 in the course of integration. In other words,
[tex]\begin{align*}\left<p\right> &= \frac{\hbar}{i2a}(1 - 1 + 0 + 1)\end{align*} = \frac{\hbar}{i2a}[/tex]
First of all, is this reasonable for the momentum to have an expectation value that is imaginary?
Second, how would I compute [itex]\left<p^2\right>[/itex] given that the second derivative of the wave function, which is summation of Heavisides, would result in a derivative of a Dirac delta function?
Thanks very much everyone! :)
Suggestion: Write the wavefunction in momentum (k) space by taking the F.T. I think you might then be able to compute the mean and ## \sigma^2 ## for the k-space wavefunction. Not sure why your above calculation isn't working, but it just doesn't seem to be getting good results. Perhaps writing the wavefunction as a linear combination of two step functions doesn't accurately describe its momentum content, but I'm not quite sure why.
Likes loginorsinup
One problem is your claim that
$$\int_{-\infty}^\infty H(x)\delta(x)\,dx = 1.$$ Instead, you should have
$$\int_{-\infty}^\infty H(x)\delta(x)\,dx = \frac 12.$$ Using this result, you find that ##\langle p \rangle = 0##. You have to be careful when using the delta function and the Heaviside step function. Take a look at http://mathworld.wolfram.com/HeavisideStepFunction.html.
Charles has a good suggestion, but you'll still run into a problem calculating ##\langle p^2 \rangle##. The Fourier transform of ##\psi(x)## will give you a sinc function, but when you throw in the factor of ##p^2##, you end up with the integral of ##\sin^2 p##, which won't converge.
Likes loginorsinup, Charles Link and BvU
That's an interesting perspective, though the next comment says that it might not be so helpful for the end result.
That's useful. I'll give it a shot, but then after finding [itex]\left<p\right>[/itex], I am still left with the situation where I have to take a derivative of a Dirac delta in order to compute [itex]\left<p^2\right>[/itex]. How do I tackle that? Thanks to both of you for your suggestions!
Likes Charles Link
In college, we worked a similar calculation with a Gaussian and we had no trouble showing that the (delta p)(delta x)=h/(2 ## \pi ##) or thereabouts. Could it be that the sharp corners make this one mathematically difficult? The delta x is approximately "a" which makes for a quick estimate of delta p. I would hope it is possible to get an exact answer for this one...And a follow-on-I verified vela's calculation that p^2 gives ## \int \sin^2(ka)dk ## and diverges. What if we were to just look qualitatively at ## | \phi(k)|^2=A \sin^2(ka)/k^2 ## and assign the uncertainty in k by taking the width of the central lobe, i.e. ## \delta k=2 \pi /a ## so that ## \delta p=h/a ## ? Also we can say qualitatively that ## \delta x=a ## so that ## (\delta x)(\delta p)=h ##
Likes loginorsinup and vela
If you have a regular old function ##f##, you can show that
$$\int f(x)\delta'(x)\,dx = -f'(0)$$ and if you naively apply it to H(x), you find the integral diverges, which kinda makes sense because you also find ##\langle p^2 \rangle## diverges using the Fourier transform.
Likes loginorsinup and Charles Link
I just don't think I know enough math to prove that, so, after trying for a bit, I gave up on trying to prove that equation you provided is true, and just took it for granted. I'm not even sure it makes intuitive sense to me, but taking the derivative of a distribution produces some weird results for me in my mind -- like the doublet.
Anyway, I was able to use that to show that [itex]\left<p^2\right>[/itex] is infinite and therefore the uncertainty in momentum is infinite. However, I find that [itex]\left<x\right>[/itex] is 0 and [itex]\left<x^2\right>[/itex] is [itex]\frac{a^2}{3}[/itex]. This means that the uncertainty in position is [itex]\frac{a^2}{3}[/itex]. So, how would I find the uncertainty product if the uncertainty in momentum is infinite and the uncertainty product is just the product of the uncertainty in position and the uncertainty in momentum?
I suspect I should find that the Gaussian satisfies the minimum uncertainty product relation -- meaning that it should give an uncertainty product of [itex]\frac{\hbar^2}{4}[/itex], but, given that my uncertainty in momentum is infinite, I'm not sure how to do that.
Any further help would be very appreciated. I'm just stuck and it's the little tricks I'm blind to that help me crack this problem!
Please read my last posting more carefully. It has two different parts. 1) The Gaussian is somewhat straightforward, but a separate calculation. 2) The ## sin^2(ka)/k^2 ## has infinite expectation for k^2 as vela first mentioned, but you can still assign an uncertainty to it in a different manner. If you look at the graph of the function, (it is incidentally the same form that shows up in the intensity pattern for the single slit diffraction calculation), it has a central lobe and setting ## ka=\pi ## gives you the first zero of the function. The central lobe goes from ## ka=\pi ## to ## ka=-\pi ## . This seems to be one of the better ways to assign a width of the spread in k or p (## p=hk/(2 \pi) ##) to this problem.
Likes loginorsinup
I think I follow, now. Basically I can specify the height of the delta function at the origin as an idealization of a distribution that gets arbitrarily tall.
Thank you! :)
Thank you! :)
The integrated area under the delta function (spike) is equal to 1, thereby when integrated with another function, it will pick off the value of that function.
Related to Simple (Constant) Wavefunction -- Find Uncertainty In p^2
1. What is a simple (constant) wavefunction?
A simple (constant) wavefunction is a mathematical function that describes the behavior of a particle in a particular quantum state. It is a solution to the Schrödinger equation, which is the fundamental equation of quantum mechanics.
2. How do you find the uncertainty in p^2 for a simple (constant) wavefunction?
The uncertainty in p^2 for a simple (constant) wavefunction can be found by taking the square root of the expectation value of p^2. This can be calculated by taking the integral of the wavefunction multiplied by p^2 over all space.
3. What is the significance of finding uncertainty in p^2 for a simple (constant) wavefunction?
The uncertainty in p^2 is a measure of the spread or variability in the momentum of a particle described by the wavefunction. It is a fundamental concept in quantum mechanics and is related to the Heisenberg uncertainty principle.
4. Can the uncertainty in p^2 for a simple (constant) wavefunction be zero?
No, the uncertainty in p^2 cannot be zero for a simple (constant) wavefunction. This is because of the inherent uncertainty in quantum mechanics, which states that it is impossible to know both the exact position and momentum of a particle at the same time.
5. How does the uncertainty in p^2 for a simple (constant) wavefunction relate to the particle's energy?
The uncertainty in p^2 is related to the particle's energy through the uncertainty principle. This principle states that the product of the uncertainties in position and momentum must be greater than or equal to a certain value, known as Planck's constant. This means that a smaller uncertainty in p^2 results in a larger uncertainty in the particle's energy, and vice versa.
