Simple critical point question - how to specify?
In summary, the critical points subject to the constraints 0<=x, y<=Pi can be classified as follows: (n*Pi,m*Pi) where m <=1 and n and m are all positive and negative integers (Z), where 2x=y and where 2y=x but only when x and y=0, and where y=1/3 Pi(2m-n) where 2m-n<3 and x=1/2 Pi(2n-m) where 2n-m=>0 or 2n=>m.
Gekko
71
Classify the critical points subject to the constraints:
0<=x, y<=Pi
fx=sin(y)sin(2x+y)
fy=sin(x)sin(2y+x)
Clearly one set of critical points will be (n*Pi,m*Pi) where m <=1 and n and m are all positive and negative integers (Z)
Another will be where 2x=y and where 2y = x but this is only true where x and y = 0
Another is where 2x+y = n*Pi and 2y + x = m*Pi
I think that is it covered however how do I write this in a precise mathematical way?
0<=x, y<=Pi
fx=sin(y)sin(2x+y)
fy=sin(x)sin(2y+x)
Great!
Solve this pair of equations for x and y. The solutions, of course, will depend on "mPi" and "nPi" and I suspect (0, 0) will be included in it.
Thanks a lot for your replies. So is it enough to simply say:
Is this enough to describe the critical points in a mathematically correct way?
FAQ: Simple critical point question - how to specify?
What is a simple critical point?
A simple critical point is a point in a phase diagram where the liquid and gas phases of a substance coexist at a single temperature and pressure. At this point, the Gibbs free energy of the two phases are equal, resulting in no net transfer of molecules between the phases.
Why is specifying a critical point important?
Specifying a critical point is important because it allows us to accurately describe the behavior of a substance at that point. This information is crucial in understanding the properties and behavior of a substance under different conditions and in various applications.
How is a simple critical point specified?
A simple critical point is typically specified by its temperature, pressure, and composition. These parameters can be determined experimentally or calculated using thermodynamic equations and phase diagrams.
What factors affect the critical point of a substance?
The critical point of a substance is affected by its molecular structure, intermolecular forces, and external factors such as pressure and temperature. Changes in these factors can shift the critical point, resulting in different behavior and properties of the substance.
What are the applications of understanding simple critical points?
Understanding simple critical points is important in many fields, including chemistry, engineering, and materials science. It allows us to accurately predict the behavior of substances under different conditions, which is crucial in designing and optimizing processes and materials for various applications.
