Simple Electrostatics Lab: Clarification
In summary, the speaker is conducting a lab to rank common household materials based on electronegativity. They are instructed to use two plastic combs and two pieces of string to hang them freely off a table. They are also instructed to acquire materials such as rubber, wool, cotton, glass, and plastic wrap. The procedure involves rubbing one comb with wool to give it a negative charge and using it as a testing device to determine the electronegativity of other substances. The second comb is necessary to determine the polarity of the charges and the speaker is unsure if they need to charge the objects themselves or if they are already partially charged. The textbook instructs not to bring the two combs together to determine polarity, but the speaker
tiffanysnsd
23
So I have to do a lab, where I rank common household materials based on electronegativity.
I am told to acquire two plastic combs and two pieces of string with which to hang them freely off a table. Besides that, I am to acquire common household materials such as rubber, wool, cotton, glass, plastic wrap, etc.
The explanation for procedure is kind of limited. From what I gather, I am to tie together the piece of string with the comb and to suspend it from the edge of a table. Then I rub it in wool to give it a negative charge and thereafter use it as a testing device: when I bring charged substances near the comb (without touching), whether they are attracted or repelled will allow me to determine their electronegativity or electropositivity. The degree of attraction or repulsion will allow me to rank them.
So, as far as that goes, I think I have things right. But I do not know why I need two plastic combs. Is it necessary to use the second plastic comb to charge the household materials? In other words, do I go about rubbing, say, cotton against the plastic comb to charge it? Do I assume that these materials are to some extent charged before doing anything to them?
If someone could please clarify how to make this experiment work, I would be very grateful.
When you rub against the comb, you don't know if it gains a positive or negative charge, right? Thus you rub one comb with, say, cotton, and the other with rubber. If the combs attract, they have opposite charges.
Yes, that is already clear.
I am seeking the purpose of the second comb, if there is any.
Also, I am seeking to know whether I have to charge the objects myself (perhaps using the second comb), or whether I can expect to find them partially charged in their natural state.
The purpose of the second comb is to find out the polarity of the charges! You have no way of knowing if you're using just a single comb. You shouldn't expect to find them charged in their natural state.
Ahh, that was my guess. What threw me off was the mention of two strings corresponding to each of the combs. Why two combs AND two strings? It doesn't seem necessary to hang the second comb.
The other thing was that my textbook instructed that I also use materials such as rubber and glass. But I suppose they are not exempt from being charged by a plastic comb.
I hope I'm on the right track.
That's because you shouldn't be touching the charged comb. If you do, you'll act as an Earth and the comb will be discharged.
As for the other materials, it's for you to try and find out =D
I considered that possibility, that touching the second comb would serve to ground it. So let me get this straight, if the second comb is suspended and rubbed against an object or material, it will serve to charge the object? Would I not be grounding the object by holding it?
If this is of any use, my textbook specifically instructs that the comb charged by wool is to be brought into proximity with the object/material; the two combs will not be brought into near contact with each other.
Both the object and the comb will be charged. What you really want is the comb to be charged, not the objects!
Well if the first of the two combs, the testing device, is permanently charged (by wool), then don't the objects you bring near it need to be charged? Like I said, the book instructs that the comb charged by wool and the objects, one by one, will be brought within proximity. So both would need to be charged.
You have to charge both combs separately, then bring them together to see if they attract or repel.
But my textbook writes:
"Begin by tying the string to one of the plastic combs and suspending this comb from the edge of a table so that it hangs freely. Rub the suspended comb in wool to give it a negative charge. Plastic rubbed in wool acquires a negative charge, so plastic is more electronegative than wool. The suspended comb will be your testing device for determining the presence of a charge
Now bring other charged substances, one by one, near to the charged suspended comb, but do not let them touch. If the comb moves toward the charged objects, then the two (comb and object) have opposite charged. If the comb moves away, then the two have the same charge."
Hence my confusion. My textbook rules out bringing the two combs together to determine polarity. So I assumed that the second comb would be used to charge the object, which the object is then brought closer to the first comb charged by wool. But by holding the object, after rubbing it in whatever material, doesn't my touching it serve to ground it. Then how is this experiment possible?
Hm, maybe the discharging effect of you touching it is not that significant after all...>.<
Related to Simple Electrostatics Lab: Clarification
1. What is the purpose of the Simple Electrostatics Lab?
The purpose of the Simple Electrostatics Lab is to demonstrate the principles of electrostatics, including the behavior of charged objects and the effects of electric fields.
2. What materials are needed for the lab?
The materials needed for the Simple Electrostatics Lab include a charged object (such as a balloon or comb), a neutral object (such as a piece of paper or plastic), and a source of electric charge (such as a Van de Graaff generator or rubbing two objects together).
3. How does the lab simulate real-life electrostatics?
The lab simulates real-life electrostatics by using the same principles and concepts that govern the behavior of charged objects in the natural world. By manipulating the charges on objects and observing their interactions, we can better understand how electric fields and static electricity work.
4. Can the lab be modified for different levels of understanding?
Yes, the Simple Electrostatics Lab can be modified for different levels of understanding. For younger students, the lab can be simplified and focused on basic concepts, while for more advanced students, the lab can be expanded to include more complex experiments and explanations.
5. What are some safety precautions to keep in mind while conducting the lab?
Some safety precautions to keep in mind while conducting the Simple Electrostatics Lab include avoiding contact with high voltage sources, using gloves or insulating materials when handling charged objects, and keeping the lab area free of water to prevent electrical shocks. It is also important to follow all instructions and guidelines provided by the lab manual or instructor.
10K
10K
