Simple geometry problem -- Find the perimeter of the triangle ABC
The discussion revolves around solving a geometry problem to find the perimeter of triangle ABC, given certain lengths and relationships between the sides. The known lengths include AC = 14 and BX = 16, with several suspected equalities among the sides. Participants note that the internal angles of the triangle sum to π and suggest using basic algebra rather than trigonometry to solve the problem. Ultimately, the perimeter is calculated to be 60, derived from the relationships established in the problem. The conversation also touches on a typo regarding the term "circumcised" in relation to circles.
docnet
what is the perimeter of the triangle ABC?
##\angle A+\angle B + \angle C = \pi##
Hello, so I saw this problem on a website while looking up trigonometric identities and trying to solve it.
what I know:
The internal angles add up to pi
Let the tangent point between A and B be X
Let the tangent point between B and C be Y
Let the tangent point between C and A be Z
## \overline {AC} = 14##
## \overline {BX} = 16##Things I suspect are true, but have yet to prove:
##\overline {AX} =\overline {AZ}##
##\overline {CZ} =\overline {CY}##
##\overline {BX} =\overline {BY}##
Relations:
##\overline {CY}=14-\overline {AZ}##
##\overline {AX}=\overline {AB}-16##so far I only found three unknowns and only two equations! I think that this is strangely difficult.
Um, the circle is circumcised?
...anyway, yes, these are true:
which you can see by, e.g. considering the right angled triangles ##AXP## and ##AZP## with common hypotenuse, etc.
Now you can see the answer just by looking at the figure, but if you like, denote the three relevant lengths by ##a,b,c## (i.e. ##a+c = 14, b=16##) and do it algebraically.
  • Haha
Likes DaveE, berkeman and BvU
@ergo: you rob docnet of the exercise this way!
PF normally restricts help to guiding questions and hints...
which you can see by, e.g. considering the right angled triangles AXP and AZP with common hypotenuse, etc.
Now you can see the answer just by looking at the figure, but if you like, denote the three relevant lengths by a,b,c (i.e. a+c=14,b=16) and do it algebraically.
aha! the perimeter of the triangle is 16+ 16+14+14 =60. thank you ! it seems obvious now
and I did not realize that it says circumcised. It was probably a typo.
Likes berkeman
Else the triangle would have been larger.
docnet said:
Homework Statement:: what is the perimeter of the triangle ABC?
Relevant Equations:: ##\angle A+\angle B + \angle C = \pi##
what I know:
Relations:
Notice the three isoscelese "triangles" created by the circles tangent points? You don't need any trigonometry to solve this only basic algebra and that fact.
As noted in post #2, and used in post #3.
Likes valenumr
Yeah, I just answered quickly without reading the thread. A better explanation was also provided proving the equal triangles.
