MHB Simple Grammar Problem: Is "a" or "the" Ideal in Lie Algebra?
  • Thread starter Thread starter topsquark
topsquark
Insights Author
MHB
My slight confusion here is probably a simple grammatical problem.
Let h and k be ideals of a Lie algebra g.
Now let h be a maximal solvable ideal (i.e.one enclosed in no larger solvable ideal) of g. If k is any other solvable ideal, then so is h + k, and thus the maximality requirement implies h + k = h and hence [math]k \subseteq h[/math].
My question is about the "a." I'm thinking that it should be "the." Aren't all ideals subalgebras of the maximal ideal?
Also: How do you pronounce "Lie?" Is it "lee" or "lye?"
-Dan
topsquark said:
...Also: How do you pronounce "Lie?" Is it "lee" or "lye?"
-Dan
It is "lee":
https://www.princeton.edu/~achaney/tmve/wiki100k/docs/Lie_algebra.html
Hi,
There is only one maximal solvable ideal, but the "a" fits better than a "the", because the uniqueness is proved after you have choose the maximal solvable ideal. (Sometimes I'm too demanding, huh?(Wondering)).
This ideal is also called the radical of the Lie algebra g (It will probably appear just after this proof if you have read it on a book.)
Fallen Angel said:
Hi,
It's a good point. And yes, the text did immediately then show uniqueness. I didn't consider the logical order there since I already knew the maximal solvable ideal was unique.
Thanks!
-Dan
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
