Simple harmonic motion (4 questions)
In summary, the conversation covers various problems related to simple harmonic motion and suspension systems. The first problem involves a block suspended from a spring and a bullet being fired into it, resulting in harmonic oscillation. The amplitude and fraction of kinetic energy in the oscillation are to be found. The second problem looks at the suspension system of a car and estimates the values of k and b for the spring and shock absorber. The third problem involves a car driving over a rough road and the effect on its suspension and weight. The final problem deals with a mass attached to a string and its oscillation, with the need to find the velocity and tension at certain points.
jin
1. A 4.0kg block is suspended from a spring with force constant of 500N/m. A 50g bullet
is fired into the block from directly below with a speed of 150m/s and is imbedded in
the bloack. (a) Find the amplitude of the resulting simple harmonic motion. (b) What
fraction of the original kinetic energy of the bullet appears as mechanical energy in the
harmonic oscillation?
2. Assume that you are examining the characteristics of the suspension system of a 2000kg
automobile. The suspension “sags” 10cm when the weight of the entire automobile is placed
on it. In addition, the amplitude of oscillation decreases by 50% during one complete
oscillation. Estimate the values of k and b for the spring and shock absorber system of one
wheel, assuming that one wheel supports 500kg.
3. A 2200lb car carrying four 180lb people drives over a rough “washboard” dirt road with
corrugations 13ft apart. The car bounces with maximum amplitude when its speed hits
10mi/h. The car now stops and the four people get out . By how much does the car rise
on its suspension owing to this decrease in weight?
4. A small mass with m = 100 grams is attached to a vertical string of length l = 2m in
the earth’s gravity. The mass swings back and forth with no loss of energy. The maximum
angle from the vertical is 45. This problem is not simple harmonic motion because the
maximum angle of displacement is not small. Find the velocity when the string is vertical,
 = 0. Find the tension in the string at  = 0. What is the velocity at  = 0 if you assume
simple harmonic motion?
need help studying for it..please help! thx
You should post this in the HWK help section! Also, what have YOU done on these problems so far? What are you stuck on? How far have you got?
for #2 i didn't get part a...i just found the amplitude using A = sqrt((x^2) + ((v^2)/(w^2)) but i heard I'm suppose to be solving for y? the others I'm just totally confused @@
FAQ: Simple harmonic motion (4 questions)
What is simple harmonic motion?
Simple harmonic motion is a type of periodic motion in which an object oscillates back and forth around an equilibrium position due to the restoring force of a spring or a pendulum.
What is the formula for calculating the period of simple harmonic motion?
The period of simple harmonic motion is calculated using the formula T = 2π√(m/k), where T is the period in seconds, m is the mass of the object in kilograms, and k is the spring constant in N/m.
What is the difference between simple harmonic motion and uniform circular motion?
The main difference between simple harmonic motion and uniform circular motion is the direction of the restoring force. In simple harmonic motion, the restoring force is always directed towards the equilibrium position, while in uniform circular motion, the restoring force is always directed towards the center of the circle.
What factors affect the frequency of simple harmonic motion?
The frequency of simple harmonic motion is affected by the mass of the object, the spring constant, and the amplitude of the oscillation. As the mass or spring constant increases, the frequency decreases. As the amplitude increases, the frequency increases.
