Simple Harmonic Motion and friction
In summary: Xo - A)sin(wt) and 0 = -wXocos(wt)Solving for t, we get t1 = π/2w and t1 = 0, respectively. Plugging these values into the corresponding solution, we get x1 = Xo - A and x1 = Xo, respectively. Therefore, the solution for part d is:t1 = π/2w and x1 = Xo - A (when 2kXo > μmg)t1 = 0 and x1 = Xo (when 2kXo =< μmg)In summary,
henryc09
72
Mass m moves along a line on a rough table and is attached on either side to a stretched spring (both have equal spring constants k). The coefficients of static and sliding friction between mass and the table are equal with value [tex]\mu[/tex]
(a) show in the abscence of friciton the particle executes SHM with angular frequency[tex]\omega[/tex] [tex]\sqrt{2k/m}[/tex]
(b) Now include the effect of friction. Suppose particle is released at time t=0 with positive displacement Xo from equilibrium. Describe initial motion when (i)2kXo> [tex]\mu[/tex]mg and (ii) when 2kXo =< [tex]\mu[/tex]mg
(c) For case (i) write down the equation of satisfied by the displacement x of the mass as long as it remains moving. Verify it is satisfied by a solution of the form:
x(t)=Acos(wt) + Bsin(wt) + C
and find the values of A, B and C for the data given.
(d) Find the time t1 and position x1 at which the particle next comes to rest.
Been a while since I last did S.H.M, but so far I have without friction total force on object will be -2kx which is equal to -mw2x so i can show the first bit.
For part b I said that when 2kXo > [tex]\mu[/tex]mg it will oscillate with lower frequency and it's amplitude will gradually decrease, when 2kX0 =< [tex]\mu[/tex]mg it will remain stationary.
Part C is where I'm stuck. I think -mw2x= - 2kx + [tex]\mu[/tex]mg but not sure how to show the solution and also how to go about working out the constants. Any point in the right direction would be appreciated.
Hi there,
For part C, you are correct that the equation of motion is given by -mw^2x = -2kx + μmg. To solve for the constants A, B, and C, we can use the initial conditions given in part b. For case (i), when 2kXo > μmg, the initial conditions are x(0) = Xo and x'(0) = 0 (since the particle is released from rest). Plugging these into the general solution x(t) = Acos(wt) + Bsin(wt) + C, we get:
Xo = A + C and 0 = -Awsin(wt) + Bwcos(wt)
From the first equation, we can solve for A in terms of Xo and C: A = Xo - C. Plugging this into the second equation and using the trig identity sin^2(wt) + cos^2(wt) = 1, we get:
0 = -w(Xo - C)sin(wt) + Bwcos(wt)
Since this equation must hold for all values of t, we can set the coefficients of sin(wt) and cos(wt) equal to 0:
-w(Xo - C) = 0 and Bw = 0
Solving these equations, we get B = 0 and C = Xo. Therefore, the solution for case (i) is:
x(t) = (Xo - A)cos(wt) + Xo
For case (ii), when 2kXo =< μmg, the initial conditions are x(0) = Xo and x'(0) = 0 (since the particle is released from rest). Plugging these into the general solution x(t) = Acos(wt) + Bsin(wt) + C, we get:
Using the same steps as above, we get A = 0 and C = Xo. Therefore, the solution for case (ii) is:
x(t) = Xocos(wt) + Xo
For part d, we can find the time t1 and position x1 at which the particle comes to rest by setting x'(t) = 0 and solving for t and x. Using the solution from
Hello, thank you for sharing your thoughts on this problem. You are correct in your understanding of the absence of friction in simple harmonic motion (SHM). In the absence of friction, the total force on the object is equal to -2kx, which is equal to the mass times the square of the angular frequency (w) times the displacement (x). This can be written as -mw^2x.
For part (b), you have correctly identified the initial motion of the object when considering the effects of friction. When 2kXo is greater than the product of the coefficient of friction (\mu) and the weight of the object (mg), the object will oscillate with a lower frequency and its amplitude will gradually decrease. This is due to the frictional force opposing the motion of the object, causing it to lose energy and decrease its amplitude.
When 2kXo is less than or equal to the product of \mu and mg, the object will remain stationary. This is because the frictional force will be strong enough to keep the object in place, preventing any motion.
For part (c), you are on the right track in setting up the equation for the displacement of the object in the presence of friction. As you have correctly stated, the total force on the object will now be equal to -2kx + \mu mg, where \mu mg represents the frictional force. This can be written as -mw^2x + \mu mg. To solve for the constants A, B, and C, you can use the initial conditions given in the problem. The object is released at time t=0 with a positive displacement Xo from equilibrium. This means that x(0) = Xo, and x'(0) = 0 (since the object is initially at rest). Using these initial conditions, you can solve for the constants A, B, and C in the general solution x(t) = Acos(wt) + Bsin(wt) + C.
Finally, for part (d), you can use the general solution x(t) to find the time t1 and position x1 at which the object next comes to rest. This will occur when the velocity of the object is equal to zero, so you can set x'(t) = 0 and solve for t. This will give you the time t1 at which the object comes to rest. To find the position x
Related to Simple Harmonic Motion and friction
1. What is Simple Harmonic Motion?
Simple Harmonic Motion (SHM) is a type of periodic motion in which the restoring force is directly proportional to the displacement of the object from its equilibrium position. This means that the object oscillates back and forth around its equilibrium position with a constant frequency.
2. How is friction related to Simple Harmonic Motion?
Friction is a force that acts in the opposite direction of motion, slowing down or stopping an object. In Simple Harmonic Motion, friction can dissipate the energy of the oscillating object, causing it to eventually come to a stop. Friction can also alter the amplitude and frequency of the oscillations.
3. What factors affect the period of Simple Harmonic Motion?
The period of Simple Harmonic Motion is affected by the mass of the object, the spring constant, and the amplitude of the oscillations. The more massive the object or the stiffer the spring, the longer the period. The larger the amplitude, the longer the period will also be.
4. How does friction affect the amplitude of Simple Harmonic Motion?
Friction can decrease the amplitude of Simple Harmonic Motion over time by dissipating the energy of the oscillating object. This is known as damping. The higher the amount of friction, the faster the amplitude will decrease.
5. Can friction ever increase the amplitude of Simple Harmonic Motion?
In some cases, friction can actually increase the amplitude of Simple Harmonic Motion. This occurs when the frequency of the external force (such as a driving force) matches the natural frequency of the oscillating object, causing resonance. In this case, friction can add energy to the system, increasing the amplitude of the oscillations.
