Simple Harmonic Motion and phase constant
In summary, the simple harmonic oscillator with a block of mass 45 g and a spring of spring constant 240 N/m has an initial displacement of 3.5 cm and an initial velocity of zero. The phase constant, φ, for its oscillations is arbitrary and can be solved for using the equation x=xmaxcos(ωt+φ). One possible way to solve for φ is by taking the derivative of the function to get v=-wxmsin(wt+φ) and then plugging in the values and solving for φ, which in this case results in a phase constant of zero. Another approach is to recognize that the starting position is a position of maximum displacement and that the cosine function is maximized when its argument
Dalip Saini
A simple harmonic oscillator consists of a block of mass 45 g attached to a spring of spring constant 240 N/m, oscillating on a frictionless surface. If the block is displaced 3.5 cm from its equilibrium position and released so that its initial velocity is zero, what is the phase constant, φ , of its oscillations? Assume the block moves according to the equation x=xmaxcos(ωt+φ) .
  • A :
    45o
  • B :
    30o
  • C :
    0o
  • D :
    90o
  • E :
    The phase constant is arbitrary.
What do you think?
Im really stuck on how to solve this problem. I know that the Xm is 0.035m. I also know that the w can be solved for using sqroot(k/m). But I'm stuck now on how to use this information to solve for the answer
You should not need to do any arithmetic to answer this problem. You are not asked for omega.
Assume that "initial" means t = 0. What is the situation at t=0?
since the initial velocity is zero, would u take the derivative of the function to get v=-wxmsin(wt+φ). Then plug in the values to get 0 = -240(0.035)sin[(240)(0)+φ). Then solve for φ and get zero. According to the assignment the correct answer is zero. Is this the correct way to solve it?
Yes, that is one correct way.
Another approach would be to convince yourself that the starting position is a position of maximum displacement and that the cosine function is maximized when its argument is zero.
ok thank you
Related to Simple Harmonic Motion and phase constant
1. What is Simple Harmonic Motion?
Simple Harmonic Motion (SHM) is a type of periodic motion in which the restoring force is directly proportional to the displacement from equilibrium. Examples of SHM include a mass on a spring or a pendulum swinging back and forth.
2. How is Simple Harmonic Motion represented mathematically?
The equation for Simple Harmonic Motion is x = A*sin(ωt + φ), where x is the displacement from equilibrium, A is the amplitude, ω is the angular frequency, and φ is the phase constant.
3. What is the significance of the phase constant in Simple Harmonic Motion?
The phase constant, φ, represents the initial phase or starting point of the motion. It determines the position of the object at time t = 0. A change in the phase constant will result in a shift in the position of the object on the SHM curve.
4. How does the value of the phase constant affect the motion of an object in SHM?
The value of the phase constant affects the position, velocity, and acceleration of the object in SHM. A larger value of φ will result in a greater initial displacement and a faster initial velocity, while a smaller value will result in a smaller initial displacement and a slower initial velocity. The acceleration, however, remains constant regardless of the value of φ.
5. Can the phase constant ever be negative in Simple Harmonic Motion?
Yes, the phase constant can be negative in SHM. This indicates that the object starts its motion in the opposite direction of the positive direction on the SHM curve. The actual value of φ is not significant, as it only affects the starting position of the object on the curve.
