Simple Harmonic Motion and the Reference Circle
In summary, the loudspeaker diaphragm is producing sound for 2.5 seconds in simple harmonic motion with an angular frequency of 7.54 x 10^4 rad/s. To find the number of times the diaphragm moves back and forth, the equation W = 2pi/T can be used where T represents time and W represents angular frequency. By plugging in the given values, the total angular rotation can be calculated, and by dividing this value by 2pi rad/cycle, the total number of cycles can be determined. In this case, the diaphragm moves back and forth approximately 1.89 x 10^5 times.
chantalprince
54
A loudspeaker diaphragm is producing a sound for 2.5 s by moving back and forth in simple harmonic motion. The angular frequency of the motion is 7.54 x 10^4 rad/s. How many times does the diaphragm move back and forth?
angular freq. (W for omega) = change in theta/ change in T or W = 2 (pi) (f)
W = 2pi/ T
Ok, first of all, I need some help clarifying exactly what I'm looking for. Is it the number of times it goes around the circle? So, every 2 pi would be one time?? If so, I think I need to use W = 2 (pi) f, but I have frequency and W, so how do I manipulate this so I can "count" each time it goes around in a circle? (Sorry for the naive-ness of this. This topic confuses the heck out of me)
Thanks in advance :)
If you thought of moving "back and forth" as 1 complete revolution, and I asked you how many revolutions it would make in 2.5 seconds, I doubt you would have a problem.
So, would it make 1 revolution (2 pi) in 2.5 seconds? I'm really confused I guess- what I just said doesn't make sense, becuase if it did, then the answer would just be 1, which didn't take the ang. frequency into account.
What about this:
W = 2 pi/T so 7.54 x 10^4 rad/sec (2.5 sec) = 2 pi
so, seconds cancel and I am left with radians...
Perhaps that doesn't work either, becase I'm confused as to what it really means.
I know there are 2 pi radians in one circle. And- one circle = 1 back and forth motion of the diaphragm...
Think of a spring oscillating back and forth. One cycle of the spring can be from its fully compressed state to its fully stretched state and back to its fully compressed state. This is similar to a ball traveling in a circular path. Place the circle's center at the center of an x-y coordinate system. Allow the ball to move around the circular at a constant velocity with a light shining from above and casting a shadow of the ball on the x axis. The shadow will move back and forth in simple harmonic motion as the ball moves around the circle. So, the ball will rotate 2pi radians and take T seconds to do this for one cycle. So, the angular frequency is
[tex]\omega=\frac{2\pi}{T}\frac{radians}{sec}[/tex]
where T is the period or time for one cycle. Frequency and period are related by
[tex]f=\frac{1}{T}\frac{cycles}{sec}[/tex]
so
[tex]\omega=2\pi \mbox{f}[/tex]
Radians and cycles are unitless.
Ok, so when I plug numbers into W = 2pi (f) - or do it the way I stated in my previous post (same thing) I end up with this numerical value: 1.89 x 10^5 rad = 2 pi rad Is this correct? Can you please help me understand what this means? Do I need to divide through on the left by 2 pi? If so, what does that mean?
You are given the angular frequency and the time. The product of these two, which is what you did, gives the total angular rotation. You are on the right track. You have radians on the right side of the equation and 2 pi radian/cycle on the left side. Divide both sides by 2 pi radians per cycle and you answer will be the total number of cycles. The total number of cycles is the total number of times the speaker goes back and forth.
Ok one last question- how exactly do the units work themselves out?
This is what I have:
1.89 x 10^5 rad = 2 pi rad/cycle
To isolate cycle don't I have to multiply by 2 pi on each side? Even then I would be left with 1/cycle? You said to divide by 2 pi rad/ cycle, but then what's left on the right? Nothing- so it would be zero??
Make it easy on yourself.
It's going at 75,400 radians per second.
How many radians then in 2.5 sec?
Divide that by 2π and that's the number of revolutions isn't it?
Ok- I guess that makes sense. However, in other contexts I would probably still be confused with the cycles, revolutions, etc... I just can't wrap my head around it- silly I know :shy: I have some more problems to practice with.
Thank you both, chrisk and LP- :smile:
FAQ: Simple Harmonic Motion and the Reference Circle
What is simple harmonic motion?
Simple harmonic motion is a type of periodic motion in which an object oscillates back and forth around a central equilibrium point with a constant amplitude and frequency. This type of motion can be observed in a variety of systems, such as a mass-spring system or a pendulum.
What is the reference circle in simple harmonic motion?
The reference circle in simple harmonic motion is a tool used to visualize the motion of an object in terms of its position, velocity, and acceleration. It is a circle with its center at the equilibrium point and its radius equal to the amplitude of the motion. The position of the object at any given time can be represented by a point on the circle, and the velocity and acceleration can be represented by the slope and curvature of the circle, respectively.
What factors affect the period of simple harmonic motion?
The period of simple harmonic motion is affected by two main factors: the mass of the object and the stiffness of the restoring force. In general, a larger mass or a stiffer spring will result in a longer period of motion. Additionally, the amplitude of the motion can also affect the period, with larger amplitudes resulting in longer periods.
How is simple harmonic motion related to circular motion?
Simple harmonic motion and circular motion are closely related, as they both involve the periodic motion of an object around a central point. In fact, the reference circle used to visualize simple harmonic motion can also be used to represent circular motion. The projection of the object's motion onto the x-axis of the reference circle is equivalent to the x-coordinate of a point moving in a circle with a constant speed.
Can simple harmonic motion occur in real-world systems?
Yes, simple harmonic motion can occur in real-world systems. In fact, it is a fundamental principle of many physical phenomena, such as the motion of atoms in a solid, the vibrations of a guitar string, and the motion of planets in orbit. While these systems may not exhibit perfectly ideal simple harmonic motion, they can still be approximated by the principles of simple harmonic motion.
