Simple Harmonic Motion mass homework
In summary, the acceleration of the elevator affects the spring's behavior, which in turn affects the period of oscillation of the mass. Similarly, if the mass is increased due to the putty landing on the block, the acceleration will decrease, leading to changes in the amplitude and period of oscillation.
Peter G.
442
Hi,
I am not very good with questions that ask me to asses a scenario qualitatively in SHM... So, if you guys can maybe guide/advise me how to go about these here:
1.A body is suspended vertically at the end of a spring that is attached to the ceiling of an elevator. The elevator moves with constant acceleration. Discuss the effect, if any, on the acceleration of the mass when the acceleration is downwards and upwards.
I tried thinking in terms of the forces on the mass when the elevator is accelerating upwards: (tension in the spring must exceed the weight of the mass) and on the way down (weight must exceed tension in the spring) but I thought greater forces would increase the amplitude and that has no effect on the period but I am probably not correct. I don't know, I really need some help on this one!
2. Discuss qualitatively the effects of this, if any, on the amplitude and period of oscillation in the following two separate cases in which the putty lands on the block: a) When the block moves past its equilibrium position and b) when the block is momentarily at rest at maximum displacement
So, if the putty lands on the mass, the mass of the system will increase, hence, the acceleration will decrease in both cases. When the acceleration decreases the amplitude or the omega has to change... I don't know...
I hope this is enough evidence I've been extracting as much of my brain as possible!
Thanks,
Peter G.
Peter G. said:
Hi,
Thanks,
Peter G.
One way is to look at this is as "fictitious forces in an accelerated frame of reference".
If the mass was hanging on the spring in a stationary lift, the spring would be extended a certain amount - the distance determined by the mass and the spring constant. Now the mass does not alter during these observations.
If the lift is accelerating up, the spring will be stretched a little more. From the "ficticious force" idea, this means the spring is behaving as if it has a smaller spring constant [the spring is weaker]. This "new spring constant will result in a different period of oscillation.
If the lift is accelerating down, the spring will be extended less than before. The spring will be behaving as if it is stronger - has a higher spring constant. This will have an affect on the period of oscillation as well.
FAQ: Simple Harmonic Motion mass homework
What is Simple Harmonic Motion?
Simple Harmonic Motion (SHM) refers to the back and forth motion of an object around a central point, where the acceleration is directly proportional to the displacement and always directed towards the central point. This type of motion can be seen in various systems such as pendulums, springs, and vibrations.
How is mass related to Simple Harmonic Motion?
Mass plays a crucial role in Simple Harmonic Motion as it affects the frequency and period of the motion. The larger the mass, the slower the motion, resulting in a longer period. This is because a larger mass requires more force to accelerate, causing a decrease in the frequency of oscillation.
What is the equation for calculating the period of Simple Harmonic Motion?
The period (T) of Simple Harmonic Motion can be calculated using the equation T = 2π√(m/k), where m is the mass of the object and k is the spring constant. This equation shows the inverse relationship between mass and period, as discussed in the previous question.
How does changing the amplitude affect Simple Harmonic Motion?
The amplitude of Simple Harmonic Motion refers to the maximum displacement of the object from its central point. Changing the amplitude has no effect on the frequency or period of the motion but does affect the maximum speed and acceleration of the object. A larger amplitude results in a higher maximum speed and acceleration, while a smaller amplitude results in a lower maximum speed and acceleration.
Can Simple Harmonic Motion occur without an external force?
No, Simple Harmonic Motion requires an external force to be maintained. This force can come from a spring, gravity, or another source. Without an external force, the object will not experience the restoring force necessary for SHM and will either remain at rest or continue in a straight line with a constant velocity.
