Simple Harmonic Motion of an air-track glider
In summary, the conversation involves five physics questions, where the individual asks for help in solving them. The questions involve topics such as simple harmonic motion, period, amplitude, velocity, and spring constant. The expert offers help by providing answers and pointing out where the individual may have made a mistake in their calculations.
saralsaigh
I have several questions i will write all of them and give you my attempt at a solution, hope you can help me figure out what i am doing wrong, Thanks.
Question 1:
An air-track glider is attached to a spring. The glider is pulled to the right and released from rest at t=0.00 s. It then oscillates with a period of 11.4 s and a maximum speed of 52.9 cm/s. What is the glider's position at t=0.561 s?
==> ANSWER:
T = 11.4s, Vmax = 52.9 cm/s
I found out W (angular frequency) to = 0.175 pi = 0.55498 rad/s
I also found A = 96.22 cm I used the equation
X(t) = A cos ( w t )
X(0.561) = (96.22) cos ( 0.55498 x 0.561 )
= 96.2186 cm
apparently this is the wrong answer...idk wat i am doing wrong though..any pointers?
Question 2:
A 543.0 g mass oscillates with an amplitude of 12.4 cm on a spring whose spring constant is 27.3 N/m. At t=0.00 s the mass is 4.36 cm to the right of the equilibrium position and moving to the right. Determine the phase constant. Use a cosine function to describe the simple harmonic motion.
==> ANSWER:
Knowns: Xinitial = 4.36 cm A= 12.4 cm
phase constant = cos^-1 ( Xinitial / A )
= cos^-1 (4.36 / 12.4)
= 69.41 rad...i think the units are radian rite?
Again i got the wrong answer and idk where i went wrong...
Question 3:
An object in simple harmonic motion oscillates with a period of 4.00 s and an amplitude of 9.79 cm. How long does the object take to move from x=0.00 cm to x=6.50 cm?
==> ANSWER:
Knowns: T=4s A= 9.78m
I found: w= 2pi/ T = 0.3927 rad/s
Vmax = wA = 3.845 cm/s
i have no idea how else to go about this question...any suggestions?
Question 4:
The velocity of an object in simple harmonic motion is given by v(t)= -(0.226 m/s)sin(15.0t + 2.00π), where t is in seconds. What is the first time after t=0.00 s at which the velocity is -0.110 m/s?
==> ANSWER: so since the equation for velocity is
V(t) = -(Vmax) sin ( wt + phase constant )
we know that,
Vmax = 0.226m/s W= 15 rad/s phase constant= 2pi rad
i figured that the speed would be the same after a period...so i set out to find the period,
T = 2pi / w = 0.4189s
however that is the wrong answer, is there a flaw in my logic?
Question 5:
A 6.00 g spider is dangling at the end of a silk thread. You can make the spider bounce up and down on the thread by tapping lightly on his feet with a pencil. You soon discover that you can give the spider the largest amplitude on his little bungee cord if you tap exactly once every 7.00 s seconds. What is the spring constant of the silk thread.
==> ANSWER:
m= 6g = 0.006 kg
T= 7s
k = ?
I used the equation T = 2pi ( m / k )^(1/2)
i rearranged it for k = (m 4pi) / T^2 = 1.54 x 10^-3 N/m
again this was the wrong answer...please help.
Sry for posting so many questions but i didnt want to start many threads and the topic is all related its just that I am studying for a test and these are the questions I am stuck on...any help would be greatly appreciated..THANKS AGAIN!
1.The physics part seems to be correct.However I'm getting something like 91 as the answer.if that is close to the correct answer you need to check your calculations,put exact value of pi and stuff.
2.Your calculator is not in radian mode.
3.you know x as a function of t.so you can write t as a function of x.take it from there.
4.Are you sure you have got the equation correct?anyways have you tried using the formula directly?
5.You made a mistake while rearranging.check it.
1- yea i wasnt in radian mode ...THANKS
2- I tried it in radian and i got 1.212 and its also wrong :S
3- i can rearrange the x(t) equation to have it as a function of t but i have two x's...im confused...
4- yea i believe its the rite equation and i did try it and i got the same answer
5- i couldn't find my mistake so i just plugged in the numbers and then rearranged and i still got the same answer :/
2.how can that be wrong??i'm stumped.
3.how would you do it if you were to calculate the distance traveled b/w say,t=1 and t=2?think a bit and I'm sure you'll find a way.
4.the same answer??what you've found there is just the time period of the shm.
remember that a 2pi phase change gives the same value of sine function.i'm getting a much lower value - less than 1/10th of your value.is that correct?
5.yet there is a mistake.something you didn't square...
Related to Simple Harmonic Motion of an air-track glider
1. What is Simple Harmonic Motion (SHM)?
Simple Harmonic Motion refers to the back-and-forth or oscillatory motion of an object around a fixed point, typically following a sinusoidal pattern. It occurs when a restoring force is applied to an object that is proportional to its displacement from its equilibrium position.
2. How is an air-track glider used to demonstrate SHM?
An air-track glider is a cart that moves with minimal friction on a track using a cushion of air. It is commonly used in physics experiments to demonstrate SHM because it allows for smooth, low-friction movement that closely approximates the ideal conditions for SHM.
3. What factors affect the period of a glider's oscillation on an air-track?
The period of oscillation for a glider on an air-track is affected by several factors, including the mass of the glider, the strength of the restoring force, and the length of the track. It is also affected by any external forces, such as air resistance, that may act on the glider.
4. How is the period of a glider's oscillation calculated?
The period of oscillation for a glider on an air-track can be calculated using the equation T = 2π√(m/k), where T is the period, m is the mass of the glider, and k is the spring constant of the restoring force. This equation assumes ideal conditions and neglects the effects of any external forces.
5. How can simple harmonic motion be applied in real-life situations?
Simple Harmonic Motion can be observed in many real-life situations, such as the swinging of a pendulum, the vibrations of a guitar string, and the motion of a spring. It is also used in engineering and design, such as in the construction of buildings and bridges, to ensure stability and minimize the effects of external forces.
