Simple Harmonic Motion (will be the death of me)
The discussion revolves around solving a problem related to simple harmonic motion, specifically finding the time at which the displacement reaches its first maximum. The equation of motion provided is x = (27.1 m) sin(16.0 t + 0.7). Participants suggest that to find the maximum, one must set the derivative of the displacement equation to zero, leading to the condition cos(16t + 0.7) = 0. There is confusion regarding the correct time value, with one participant initially calculating 5.58 seconds, while others suggest that using radians might yield a more accurate answer of approximately 3.196 seconds. The discussion emphasizes the importance of correctly applying trigonometric principles and ensuring calculator settings are appropriate for the calculations.
-Chad-
The motion of an object is simple harmonic with equation of motion x = (27.1 m) sin(16.0 t /s + 0.7). At what time after t = 0 will the displacement reach its first maximum (where velocity equals zero)?
(displacement)=Asin(freq.*t+phase)
"(27.1)(sin((16x)+.7))" into calculator. Where y=displacement and x=time.
I calculate the first maximum to be at (5.58,27.1). Since the question asks for the time my answer would be 5.58 seconds. But this is wrong, and I'm not sure where I went wrong..
Any help greatly appreciated, Thanks!
Hi -Chad-, welcome to PF.
At the maximum the velocity is zero. So find dx/dt and equate it to zero. From that find arc cos to find t.
How did you get t=5.58s ? If I put that value into the equation for x, I don't get 27.1. (Unless my calculator is messing up)
Does 3.196 s sound like a better answer?
I changed my calculator from degrees to radians. (if this fixes my problem, sorry for the stupid mistake)
If not, rl.bhat, I do not understand what you want me to do. If I take the derivative at the maximum, where velocity is zero, it will also be zero.
In the problem dx/dt = (27.1m)(16.0)cos(16*t + 0.7) = 0.
Now at what angle cosθ = 0?
Equate that angle to 16*t + 0.7 to find t.
How did you get 3.196 s? Derive x = (27.1 m) sin(16.0 t /s + 0.7) and you'll get the equation for velocity. Set the velocity to 0 and you'll be able to solve for t.
?? ok, first rl.bhat, cos90=0 90=16t+.7 89.3=16t 5.58=t (same answer i already got)
ideasrule, i get the same answer when doing what you want me to do. I'll write out my derivation just for thoroughness.
________________d/dt[(27.1)(sin(16t+.7))]
product rule______(27.1)(d/dt[sin(16t+.7)])+(d/dt(27.1))(sin(16t+.7))
d/dt(sinx)=cosx___(27.1)(cos(16t+.7))+(0)(sin(16t+.7))
________________27.1cos(16t+.7)
27.1cos(16t+.7)=0
cos(16t+.7)=0
cos^-1(cos(16t+.7))=cos^-1(0)
16t+.7=90
16t=89.3
t=5.58
Try using radians, 16t+0.7 = Pi/2
  • · Replies 51 ·
