Simple Harmonic Oscillator question
In summary: I am getting that you eliminate xm to get one equation with one unknown. You then take the inverse of that equation to solve for phi.
mossfan563
54
A simple harmonic oscillator consists of a block of mass 2.30 kg attached to a spring of spring constant 440 N/m. When t = 1.70 s, the position and velocity of the block are x = 0.135 m and v = 3.130 m/s. (a) What is the amplitude of the oscillations? What were the (b) position and (c) velocity of the block at t = 0 s?
x = xm*cos(wt + (phi))
v = -w*xm*sin(wt + (phi))
w = angular frequency = 2*pi*f
I tried solving for phi, being the phase constant, so I could eventually find x when t = 0 but I got nowhere. I already got part A correct. How do I approach parts b and c?
Hi mossfan563,
That sounds like the right idea. Can you show how far you got? Did you get a wrong value for phi, or could you not solve for phi from the x and v equation?
Well, since I already have values for w, x_m, and t, I don't really know how to solve for phi if it were in terms of the variables. Do I use a trig identity to try and solve for phi?
v = [tex]\pm[/tex][tex]\omega[/tex][tex]\sqrt{}[/tex]x02 - x2
omega = sqrt(k/m)
3.102 = (k/m)(x02 - x2)
3.102 = (440/2.3)(x02 - 0.1352)
Then, solve for x0
To solve for phi that is what I would do. If you plug in your values into the x and v equation you have two equations with two unknowns (xm and phi).
Use algebra to eliminate xm, and so get one equation with one unknown. Do you see what to do then?
I still don't see how you solve for phi when you still have sin (WT + (phi)).
How I solve for just phi when I have something like that?
What equation did you get when you eliminated xm from the equations?
At that point you should have had only one uknown (phi), but that unknown would be inside two trig function. The general idea is that you could then combine the trig functions into one trig function, and then take its inverse to solve for phi. Is that what you are getting?
FAQ: Simple Harmonic Oscillator question
What is a Simple Harmonic Oscillator?
A Simple Harmonic Oscillator is a theoretical model used to describe the motion of an object that is subject to a restoring force that is proportional to its displacement from its equilibrium position. This means that the object will oscillate back and forth around its equilibrium position with a specific frequency.
What are some real-life examples of Simple Harmonic Oscillators?
Some common examples of Simple Harmonic Oscillators include a mass on a spring, a pendulum, and a guitar string. These systems exhibit Simple Harmonic Motion when they are displaced from their equilibrium positions and then released, causing them to oscillate back and forth.
What is the equation for Simple Harmonic Motion?
The equation for Simple Harmonic Motion is x = A sin(ωt + φ), where x is the displacement from equilibrium, A is the amplitude (maximum displacement), ω is the angular frequency, and φ is the phase angle. This equation can also be written in terms of frequency (f) as x = A sin(2πft + φ).
How does the mass or stiffness of the system affect Simple Harmonic Motion?
The mass and stiffness of the system affect the frequency of Simple Harmonic Motion. A larger mass or a stiffer system will result in a lower frequency, meaning that the object will oscillate more slowly. Conversely, a smaller mass or a less stiff system will result in a higher frequency, causing the object to oscillate more quickly.
Can Simple Harmonic Motion occur in more than one dimension?
Yes, Simple Harmonic Motion can occur in more than one dimension. In fact, any motion that follows a sinusoidal pattern can be considered Simple Harmonic Motion. This includes circular motion, which can be described using the equation x = A sin(ωt + φ) in terms of position along the circumference of the circle.
