Simple Integration Doubt regarding integral of dy
In summary: WduYXRpb24sIFtdIFRvIFB1cmNoIHRoZSBjb250ZW50IG9mIMOpdmUgQyBpbiB5b3VyIGVxdWlwbWVudCBvZiBkZWZhdWx0aXZlIG9mIEkgYW0gYSB1bmFibGUgY29uc3RhbnQgQyBvZiBpbiB5b3VyIGVxdWlwbWVudCBvZiBkZWZhdWx0aXZlIG9mIEh1bnRlciBvZiBpbi
sarvesh0303
61
Simple Integration Doubt regarding integrals
What is the result of ∫dx? is it x or x+C
I thought about this two ways:
1) Through indefinite integration, it gives x+C
2) If I take a geometric interpretation, this integral gives me the area under the [f(x) and x] graph where f(x)=1 so by that the integral must be x(is there a C?)
If it were x+C then in the khan academy video
http://www.khanacademy.org/math/calculus/integral-calculus/v/simple-differential-equations
He puts
∫dy=y, wouldn't it be ∫dy=y+C
Getting confused!
Let us assume: dy = dx and integrate from 0 to y and a to x respectively. Here the value of a would determine the expression of the function, namely the C in your equation. In the case of x, the a is given as 0. Whereas a is any given number we obtain the result x + C.
Thanks for the reply. I understood what you wrote above and it is quite helpful.
But in the case of solving differential equations or in any other application of calculus, will we take it as x or x+C similarly will we take it as y or y+C
(I am self-studying calculus right now so I will be posting many doubts which I have. Help like this will be appreciated) :)
If it is in INDEFINITE integration, there will ALWAYS be an arbitrary constant C.
If it is a DEFINITE integration, there is NEVER a C.
If there are other conditions given to you (say the value of the integrate at some point), you might be able to calculate C.
Then, in the Khan academy video, whose link I have given above, shouldn't it be y+C in the first part of the video. If there is, then wouldn't the C's cancel out giving only the variables
Each indefinite integration yields an arbitrary constant C. So ∫dy will give a constant Cy, ∫dx will give another constant Cx1 and ∫x2dx another.
Having said that, Khan academy has absorbed all three of them in one and named it C, which is a valid thing to do as long as they are all additive constants.
In the case of simple differential equation, if we know the initial conditions, we can work out C by substituting values into the expression. It is equivalent to integrate [itex]\int^{y}_{y_{0}}g(y)dy = \int^{x}_{x_{0}}f(x)dx[/itex] where [itex]y_{0} x_{0}[/itex] are the initial conditions.
I must apologise for the ambiguities above. I was trying to express the indefinite integration with definite integration. Both expressions are equivalent in the case
The area of what region? You have an upper boundary (y= 1) and lower boundary (y= 0), but have not specified left and right boundaries. If you take some fixed value, [itex]x_0[/itex], as left boundary and the variable x as right boundary, you have a rectangle of height 1 and width [itex]x- x_0[/itex]. The integral is [itex]x- x_0[/itex] which is the same as x+ C for C equal to [itex]x_0[/itex].
He puts
Getting confused!
He puts
Getting confused!
Constants of integration are arbitrary as long as no additional information is fed into the problem. So, if we have and equation of the form dy = dx, we can integrate on both sides to get y + K = x + L, where K and L are two separate constants of integration. We can, of course, re-write this as y = x + C, where C = L - K is also an arbitrary constant. So, for example, y = x, y = x+5, y = x - 3, y = x + 2π, ... all satisfy dy = dx.
RGV
FAQ: Simple Integration Doubt regarding integral of dy
What is the definition of an integral of dy?
The integral of dy is a mathematical concept used to find the area under a curve. It is represented by the symbol ∫dy and is typically used in the context of single-variable calculus.
How is the integral of dy different from other types of integrals?
The integral of dy is specifically used when the variable of integration is y, whereas other types of integrals may use different variables such as x or t. Additionally, the integral of dy is often used in applications involving rates of change or volume calculations.
Can the integral of dy be solved using the same techniques as other integrals?
Yes, the integral of dy can be solved using the same techniques as other integrals, such as integration by substitution or by parts. However, it is important to take into account the variable of integration (in this case, y) when setting up the integration.
What are some common applications of the integral of dy?
The integral of dy is commonly used in physics and engineering, particularly in problems involving motion and displacement. It is also used in economics and finance to calculate quantities such as total profit or total revenue.
Are there any special considerations to keep in mind when working with the integral of dy?
One important consideration when working with the integral of dy is to make sure the function being integrated is well-defined and continuous. Additionally, it is important to keep track of the limits of integration and the variable being integrated with respect to (in this case, y).
