Natasha1
- 494
- 9
Could anyone explain to me ultra simply by means of a mechanical approach maybe why the integration of 1/(3-0.2x)dx = -5 ln l 3-0.2x l ? thanks
quasar987 said:set y = 3-0.2x
quasar987 said:After you've set y = 3-0.2x, you also have to find dy in terms of dx. Do the calculations and you'll see where the -5 pops in.
right soNatasha1 said:dy = -0.2 and then ?
xman said:right so
[tex] -\frac{1}{0.2} dy =dx\Rightarrow -\frac{1}{2/10} dy = dx \Rightarrow - \frac{10}{2} dy =dx \Rightarrow -5dy=dx [/tex]
now substitute back into equation and integrate
A simple integration problem is a mathematical exercise that involves finding the antiderivative (or indefinite integral) of a given function. In other words, it is the reverse process of differentiation, where the goal is to find the original function when given its derivative.
To solve a simple integration problem, you need to use integration techniques such as substitution, integration by parts, or trigonometric substitution. These techniques involve manipulating the given function in a certain way to make it easier to integrate.
Some common integration rules include the power rule, where you add 1 to the exponent and divide by the new exponent, and the constant multiple rule, where you can pull out a constant from the integral. Other rules include the product rule and the quotient rule for integration.
Definite integration involves finding the area under a curve between two specific points, whereas indefinite integration involves finding the antiderivative of a function without any specific interval. In other words, definite integration gives a numerical value, while indefinite integration gives a function.
Yes, most scientific calculators have an integration function that can solve simple integration problems. However, it is important to understand the concepts and techniques behind integration in order to use a calculator effectively and check for any errors in the final answer.
