Simple lab calculation (Magneticfield vectors)
In summary, the Earth's magnetic field density (B) can be calculated by using the formula B = K x I / r where K is the proportionality constant (2 x 10^-7), I is the current (2.89amps), and r is the distance (0.035m). Using trigonometry and vector divisions, the resultant vector (B-res) can be found to be 2.016022035 x 10^-5 T. The Y-component of B-res can be calculated using Pythagoras, resulting in a value of 1.156342737 x 10^-5 T. Alternatively, the tangent of 35 degrees can be used to calculate B-earth directly from B-wire.
Xeno24
I = 2.89amps, r = 0.035m, resultant vector angle (55), proporptionality constant (2 x 10^-7)
B = K X I / r , trigonometry, vector divisions.
Hi, I'm just pasting this off my lab to make sure I've done it correctly. Thanks in advance.
Lab:
A rod is put, parallel to the Earth's magnetic field (due north)with a compass needle 0.035m below it. A flow of 2.89amps is switched on and the compass needle deviates 55 degrees due east as the current creates a magnetic field of its' own.
Question - Calculate the Earth's magnetic field density (B) using these vectors.
Using the formula above the field density for the X component is
(2 x 10^-7) x 2.89amp
------------------------------ = 1.651428571 x 10 ^- 5 Tesla
0.035m
To find the resultant vector (B-res), I used
Cos(35) = B-x/B-res, B-x/Cos(35) = B-res,
----------------------------------- = B-res
Cos(35)
B-res = 2,016022035 x 10^-5 T
And finally with Pythagoras you can find the vector of the Y-component,
______________
\/B-res^2 – B-x^2 = 1,156342737 x 10^-5 T
~ 12microT
Since the compass stays in the resultant vector (Bres),
Looks good. You could also use the fact that
tan(35 deg) = ____ / ____ ?
which gets you from Bwire to Bearth in a single step, without the need to calculate Bres.
p.s. welcome to PF :smile:
Thanks. :)
FAQ: Simple lab calculation (Magneticfield vectors)
How do I calculate the magnitude of a magnetic field vector?
To calculate the magnitude of a magnetic field vector, you can use the formula B = μ0*I/(2πr), where B is the magnetic field strength, μ0 is the permeability of free space, I is the current, and r is the distance from the current. Make sure to use consistent units for accurate calculations.
Can I calculate the direction of a magnetic field vector?
Yes, the direction of a magnetic field vector can be calculated using the right-hand rule. Simply point your thumb in the direction of the current, and your fingers will curl in the direction of the magnetic field.
How do I calculate the total magnetic field in a given area?
To calculate the total magnetic field in a given area, you can use the principle of superposition. This means that you can add up the individual magnetic field vectors at each point in the area to determine the total field. You can also use the formula B = μ0*I/(2πr) for each individual vector and then add them together.
What is the unit of measurement for magnetic field vectors?
The SI unit for magnetic field is Tesla (T). However, it is more commonly measured in Gauss (G) or microtesla (μT). 1 T = 10,000 G = 1,000,000 μT.
Can I use simple lab equipment to measure magnetic field vectors?
Yes, there are several simple lab equipment that can be used to measure magnetic field vectors, such as a compass, a Hall probe, or a magnetometer. These tools can give you an idea of the direction and strength of a magnetic field, but for more precise measurements, more advanced equipment may be needed.
