Simple Linear Algebra matrix problem
In summary, the conversation discusses how to find the value of h in the equation [1 -2 l 4] [4 -3 l 1] [-2 7 l h] for the given values of a1, a2, and b. Different approaches are suggested, including using augmented matrices and solving for x, y, and h using the equations. The correct answer is found to be h=-17.
anniecvc
28
Let a1 = [1 4 -2] supposed to be a column
Let a2 = [-2 -3 7] supposed to be a column
Let b = [4 1 h] supposed to be a column
For what value(s) of h is b in the plane spanned by a1 and a2?
Well, the first thing I did as in 99% of all Linear Alg problems was to put it into an augmented matrix:
[1 -2 l 4]
[4 -3 l 1]
[-2 7 l h]
which became from -4R1 +R2 -> R2:
[1 -2 l 4]
[0 5 l -15]
[-2 7 l h]
and I'm stuck. I could do 2R1+ R3 -> R3, but this doesn't seem to render a correct answer of h= 7/2.
I think the simpler solution is to construct the whole 3x3 matrix and take the determinant. If b lies in the plane of a1, a2, then the three of them put together no longer span all of 3D space, and the determinant of the matrix will be zero.
Hi anniecvc! :smile:
No need to be stuck.
You can divide row 2 by 5: R2/5 -> R2
Then you can use row 2 to simplify row 1.
From rows 1 and 2 you get the solution for the linear combination.
Substitute those in the equation represented by row 3 and you get h.
Personally, I prefer to do problems like this right from the definitions.
b is in the space spanned by a_1 and a_2, then it is a linear combination of them. That is, there must exist numbers x and y such that
[tex]x\begin{bmatrix}1 \\ 4\\ -2\end{bmatrix}+ y\begin{bmatrix}-2 \\ -3 \\ 7\end{bmatrix}= \begin{bmatrix}4 \\ 1\\ h\end{bmatrix}[/tex]
which is the same as
[tex]\begin{bmatrix}x- 2y \\ 4x- 3y \\ -2x+ 7y\end{bmatrix}= \begin{bmatrix}4 \\ 1 \\ h\end{bmatrix}[/tex]
which, in turn, is equivalent to the three equations x- 2y= 4, 4x- 3y= 1, -2x+7y= h.
Solve the first two equations for x and y and put those values into the third to find h.
If the required answer is 7/2, it is wrong, as can be checked easily. What you described initially does work.
Ougoah, you're right, the answer is h=-17, which using Serena's help comes out nicely. Thank you! Ivy, that does work too but I think defeats the purpose of being in a linear algebra class rather than an Alg 2 class. Still, thanks for the insight!
You're welcome! :smile:
FAQ: Simple Linear Algebra matrix problem
What is a matrix in simple linear algebra?
A matrix is a rectangular array of numbers, symbols, or expressions arranged in rows and columns. It is used to represent data in a concise and organized manner, and is a fundamental tool in linear algebra.
What is a simple linear algebra matrix problem?
A simple linear algebra matrix problem is a mathematical question that involves manipulating matrices using basic operations such as addition, subtraction, multiplication, and division. These problems can range from solving systems of linear equations to computing determinants and inverse matrices.
How do you solve a simple linear algebra matrix problem?
To solve a simple linear algebra matrix problem, you need to follow a set of steps depending on the specific problem. These steps may include identifying the given matrices, performing the necessary operations, and checking the solution for accuracy. It is also helpful to have a good understanding of matrix properties and rules.
What are some real-life applications of simple linear algebra matrix problems?
Simple linear algebra matrix problems have numerous real-life applications, including image and signal processing, data compression, computer graphics, and engineering. They are also used in economics, finance, and social sciences to model and analyze complex systems.
Can I use a calculator to solve simple linear algebra matrix problems?
Yes, you can use a calculator to solve simple linear algebra matrix problems, but it is important to understand the steps involved in solving them by hand. Calculators can help with the calculations, but they cannot provide insight into the problem-solving process. Additionally, some problems may require a specific type of calculator, such as one that can handle complex numbers for solving eigenvalue problems.
