Simple liquid/gas law question and liquid transfer query
  • B
  • Thread starter DonJuane
  • Tags
    Law Liquid
In summary, the liquid propane in the two half-full bottles will flow down from the top to the bottom tank regardless of the position of the valve on the upside down bottle.
DonJuane
I am so embarrassed that I have forgotten so much of my physics and I am at the point of being away from school too long to remember even the most basics (Mom said no one can ever rob your education but I'm living proof otherwise). So please forgive my inability to discuss this at an academic level.
Question 1:
I am having a debate with a friend. We take the example of two propane bottles and each of them is half full. Hang one upside down from a tree with the valve pointing down. Set another one on the ground with the valve pointing straight up.and connect the two with a perfectly straight hose. I told my friend that the only way the liquid will run down from the top to the bottom tank while assuming the tanks are the exact same temperature, is if there is an unrestricted path through the hose for bubbles to travel up to the top with that path constantly rising from the bottom to the top tank and where there is no place in the path where the bubbles will have to travel downhill. He says that this cannot be calculated as to if bubbles travel like this and that I in my own reference as to how this is true with transferring water from one sealed jug to another sealed jug is not accurate when it comes to propane. I say that the liquid propane matches the characteristic of water in two enclosed bottles and that the bubbles serve the same purpose with propane as they do in the water transfer example in that bubble must travel uphill for a transfer. Which of us is right?
Question 2:
Will liquid transfer from one bottle to the other over time? If we set the two half-full propane bottles on a level suface with a hose connecting both valves of both bottles, with one tank inverted and one tank straight up. Assuming the temperature of the two is approximately the same with no energy source to make one hotter than the other over time and assuming the temperature of both at exactly the same two during a cycle of daylight making them both warm and cool at the same rate over time. Will the fact that one bottle is inverted cause the liquid to move from one bottle to the other over time with uniform temperature swings on both bottles?
Science news on Phys.org
What has this question got to do with thermodynamics?
If we posit the propane condensing on the bottom surface of the suspended liquid propane and evaporating from its upper surface and a resulting heat flow through the bulk of the propane, then we have a thermodynamics problem.
How about some assistance with directing me to the right area for an answer to my question rather than further explaining my lack of knowledge and inability to categorize it properly? I think many people get so buried in their niche that they begin to dwell on skills with the mechanics of procedures rather than the grand overall spirit of simply helping a fellow out.
Likes vanhees71 and russ_watters
DonJuane said:
Question 1:
My community has a propane system with a cluster of underground tanks. I assume this is pretty much exactly how it's filled...and for that matter, how the little propane tanks for grills are filled. One issue: I don't see why the bubbles would need a constantly rising path. I don't think it would trap the bubbles if they are being forced to flow toward the upper tank by the higher pressure in the lower tank.
Question 2:
This looks like the same question and I would still say yes.
I'm not certain I'm following. Are you saying the pressure increase in the lower tank caused by the flow from the upper tank would cause the gaseous propane in the lower tank to condense? Maybe... I would think that during the transfer there would be come condensation and evaporation but the system would eventually settle out at the same pressure and temperature that it started (assuming the two tanks are at the same temp to start).
I had wondered about this problem myself years ago, and my initial guess would make this a thermodynamics problem: I had guessed that the primary tank would be over-pressurized to keep it all liquid and drive the transfer (with a compressed air bladder?). This would condense the propane in the secondary tank as it filled, making it a (minor) thermodynamics problem.
Net of it is that it doesn't seem logical to debate if something is properly categorized when in other forums, if you ask about tire pressure in a carburator section of an auto repair help-group, some friendly sort normally moves the post to the proper place with with the simple note "moved to tire forum" without a proper scolding for the mistake. Likely in the auto repair section the moderator has years of experience under his belt, realizes that simple mistakes are made, that reading and memorizing the architecture of the answer-providing medium is not also the interest of the casual rube who has a question and that in the general scheme of things, that moving the question to the proper place will be better and easier than to school the person on why tire pressure is different than carburation. You have to ask also if some ignoramous comes along and asks a grade-school physics question like this, you might also have to consider they they don't perhaps know what is categorized as thermonatics and chose the category because it didn't sound like quantum physics or at the atom splitting level (although I full expect to hear now how it could relate to that) Otherwise if someone will tell me where to re-ask this question, then please feel free to advise.
I will re-phrase my question. I want to forget thermodynamics and think of the subject here only as "my selecting the wrong topic" and let's turn this into an elementary gas/liquid question and answer session that has been miss-assigned. Considering in a perfectly controlled environment, where the temperature on both bottles was exactly the same, without a pump or a source of energy, how might one get the liquid in the bottle above to run into the bottle in the bottom. (I know I can make the tempatures different but I am talking about when that is not possible or practical.) My idea was that the propane would follow the same characteristics as with water in two sealed bottles, which is, that with two water bottles, the only way for the water in the top bottle can run down through a tube to the bottom bottle is if there is a continuously asending path for a bubble to take from the bottom tank, up through the liquid in the tube to the top tank. My assumption that liquid propane would follow the same characteristic of water but only in the case where the temperature on the two bottles of propane were kept exactly equal. True or not true?
DonJuane said:
Net of it is that it doesn't seem logical to debate if something is properly categorized...
Valid criticism, but let's move on. We'll move the thread or change the title if it seems appropriate, but I don't see it as necessary.
I will re-phrase my question. I want to forget thermodynamics and think of the subject here only as "my selecting the wrong topic" and let's turn this into an elementary gas/liquid question and answer session that has been miss-assigned. Considering in a perfectly controlled environment, where the temperature on both bottles was exactly the same, without a pump or a source of energy, how might one get the liquid in the bottle above to run into the bottle in the bottom. (I know I can make the tempatures different but I am talking about when that is not possible or practical.) My idea was that the propane would follow the same characteristics as with water in two sealed bottles, which is, that with two water bottles...
Per my response in post #5, I agree.
...the only way for the water in the top bottle can run down through a tube to the bottom bottle is if there is a continuously asending path for a bubble to take from the bottom tank, up through the liquid in the tube to the top tank. My assumption that liquid propane would follow the same characteristic of water but only in the case where the temperature on the two bottles of propane were kept exactly equal. True or not true?
Per my response in post #5, I don't think it is necessary for the path to be a continuous ascent/descent. Also, this is something that could probably be tested without too much effort with a couple of sealed 5 gallon buckets and a garden hose.
Likes vanhees71 and jbriggs444
The "hose with no continuous upward path for bubbles" resembles a bit a simple siphon barometre.
Consider the case where the barometre is filled with quicksilver. One leg is open to external air, the other closed with no air in the closed end.
The barometre would show 760 mm Hg.
The Torricelli vacuum is not actually a vacuum. It is full or quicksilver vapour... pressure 0,16 Pa at 20 C. Which is mere 0,0012 mm Hg.
Thermodynamically it would be favourable for air to travel through the quicksilver and fill the Torricelli vacuum, whereupon the barometre would show less than the true external air pressure, and eventually zero. But bubbles cannot do so.
If, however, you had only quicksilver vapour and no air in either leg, then the barometre would also show zero.
Now fill your barometre with water.
Ait supports the weight of 10 m water... but the vapour pressure of water at 20 Celsius is about 2300 Pa. Which means that water vapour supports over 230 mm water, compared to quicksilver vapour supporting just 0,0012 mm.
And now fill the barometre with propane.
At 20 Celsius, the vapour pressure of propane is about 8,5 bar, and density about 0,5. Which means propane vapour supports 170 m of liquid.
If you have a siphon barometre with propane vapour in both legs, position where a quicksilver barometre would necessarily show zero, the propane barometre would be liable to show even tiny temperature differentials between the two surfaces as differences in vapour pressure.
I think jbriggs444 has it right. The head pressure would tend to move propane down until an increase in vapor pressure stopped it. But if the temperature is constant then an increase in vapor pressure would mean it is oversaturated and would condense. Similarly in the top bottle, propane would vaporize to keep the increasing head space at saturation pressure.
In practice it would be very slow because heat has to move out of one bottle into the environment and into the other bottle. I've done LPG fuel transfers, not with propane bottles but with propane/butane mixes (backpacking canisters). The temperature (and fuel proportions in the case of mixes) makes a lot more of a difference than gravity. But I believe gravity will eventually work.
Trying to figure out if gas bubbles in LPG will fit through the valves is something I've thought about and realized I don't know how to calculate.
FAQ: Simple liquid/gas law question and liquid transfer query
What is the simple liquid/gas law?
The simple liquid/gas law, also known as the ideal gas law, is a fundamental equation in thermodynamics that describes the behavior of gases. It states that the pressure of a gas is directly proportional to its temperature and the number of moles of gas present, and inversely proportional to its volume.
How is the ideal gas law used in real-world applications?
The ideal gas law is used in various real-world applications, such as in the design of gas containers, predicting the behavior of weather balloons, and determining the amount of gas needed for a specific chemical reaction. It is also used in the study of atmospheric gases and gas mixtures in industrial processes.
What is the difference between a liquid and a gas?
Liquids and gases are both considered fluids, but they have distinct properties. Liquids have a fixed volume and take the shape of their container, while gases have no fixed volume and expand to fill the space they are in. Liquids are also more dense than gases and have a higher viscosity, or resistance to flow.
How is liquid transferred from one container to another?
Liquid transfer can be achieved through various methods, such as pouring, siphoning, and pumping. The specific method used will depend on the properties of the liquid, the containers involved, and the desired outcome. For example, siphoning is often used to transfer liquids from a higher container to a lower one without the need for pumps or additional equipment.
What factors affect the behavior of liquids and gases?
The behavior of liquids and gases is affected by several factors, including temperature, pressure, and volume. Other factors such as the type of gas or liquid, the presence of other substances, and external forces can also impact their behavior. Additionally, the properties of the container and the surrounding environment can play a role in how liquids and gases behave.
