Simple logarithm simplifications
  • Thread starter ehilge
  • Tags
    Logarithm
In summary: Yes, ec ln(x)= eln xc= xc.He thought:(e^c)^{ln(x)}=e^{c*ln(x)}=e^{ln(x^c)}=e^{c*x}=e^{x*ln(x)}=e^{x*x}=e^{x*c}=1.
ehilge
163
Hey all, I just need some help remembering my basic simplification rules.
Can the expression eC*ln(x) be simplified anymore. It would certainly help out an integral I'm working on but I don't remember my simplification real well.
elnx=x
I'm doubting there is a solution since eC*ln(x) = eclnx and I don't see how that helps much. But I thought I'd check with you guys and see if anyone had a better idea.
Thanks!
No, [itex]e^{C ln(x)}[/itex] is NOT equal to [itex]e^{C^{ln x}}[/itex]. I don't know where you got that. It is equal to [itex]e^{ln(x^C)}[/itex] (because [/itex]C ln(x)= ln(x^C)[/itex]).
HallsofIvy said:
No, [itex]e^{C ln(x)}[/itex] is NOT equal to [itex]e^{C^{ln x}}[/itex]. I don't know where you got that. It is equal to ][itex]e^{ln(x^C)}[/itex] (because [/itex]C ln(x)= ln(x^C)[/itex]).
ohhhhh, I see now, thanks!
edit: also ecln(x) is equivalent to ecln(x)
this is the same as saying that 23*2 = 232 = 64
Are you sure? Because 23*2=26 and 232=29. What you said is equivalent to saying 4*6 = 46 or 64.
As HallsofIvy said, ecln(x)=eln(xc). This can be simplified. Can you see how?
this is the same as saying that 23* = 232 = 64
No, it is not. You are not distinguishing between
[tex]\left(e^a\right)^b[/tex]
and
[tex]e^{(a^b)}[/tex]
What you are writing, eab, is equivalent to
[tex]e^{\left(a^b\right)}[/tex]
which is NOT the same as
[tex]\left(e^a\right)^b= e^{ab}[/tex].
ya, you're right, I meant to write what you have in the 2nd part there, I just wasn't liberal enough with parenthesis. Sorry, my bad.
so what I should have written in the first place is ecln(x) = (ec)ln(x) , right?
also, Kaimyn, eln(xc) simplifies to xc, if I remember my log stuff right (which obviously isn't a given) the e and the ln should essentially cancel each other out.
thanks
thanks
He thought:
[tex](e^c)^{ln(x)}=e^{c*ln(x)}=e^{ln(x^c)}[/tex]
FAQ: Simple logarithm simplifications
What is a simple logarithm simplification?
A simple logarithm simplification is the process of reducing a logarithmic expression to its simplest form by using properties of logarithms and basic algebraic rules.
What are the basic properties of logarithms?
The basic properties of logarithms include the product property, quotient property, power property, and change of base property.
How do you simplify a logarithmic expression using the product property?
The product property states that the logarithm of a product is equal to the sum of the logarithms of the individual factors. This means that if you have a logarithmic expression with multiple terms being multiplied together, you can rewrite it as the sum of individual logarithms. For example, logb(xy) = logbx + logby.
Can you simplify a logarithmic expression with a coefficient?
Yes, you can use the power property to simplify a logarithmic expression with a coefficient. This property states that the logarithm of a number raised to a power is equal to the exponent multiplied by the logarithm of the number. For example, logb(xn) = nlogb(x).
What is the change of base property and how is it used in logarithm simplifications?
The change of base property states that the logarithm of a number in one base can be rewritten as the logarithm of the same number in a different base divided by the logarithm of the original base. This property is useful when simplifying logarithms with bases that are not easily divisible. For example, log23 can be rewritten as log103 / log102.
