Simple method for testing graphene
In summary, the conversation discusses a video demonstrating a method for testing graphene which involves shaking a mixture of 50% water and 50% gasoline to separate the graphene. The authenticity of the method is questioned and the results of the experiment are compared to the video. The conversation also mentions the difficulty in obtaining true graphene from commercial sources and suggests alternative methods for creating it. The accuracy of using Raman to identify graphene is also discussed. Overall, the conversation highlights the challenges and limitations in obtaining and identifying true graphene.
Magnetosphere
64
I saw this video for testing whether one has graphene or graphite and was wondering about the authenticity of the method. By mixing 50%h2o and 50%gasoline the graphene should separate/settle in between the two within a second after shaking. Here are some pictures of my own experiment before shaking and after shaking. My graphene comes from a reputable source in England. What does the community think? The gasoline settled on top of the water. VIDEO:
After adding the graphene, graphene is settling in the gasoline after a minute.
After shaking, graphene seems to mix but bottom of the test tube is transparent which tells that the graphene is only stuck to the wall?
After 20 minutes, graphene seems to be settling in the gasoline.
Chemistry news on Phys.org
My experiment compared to the video gave a much different result in my opinion. amount of graphene in this experiment is about 0,1g I also suspect the air in the test tube might be responsible for a different result than the video.
mjc123 said:
I read an article in The Times the other week saying that nobody is actually selling true graphene, even if they claim to be. I can't find it online, but there was this: https://blogs.sciencemag.org/pipeline/archives/2018/10/11/graphene-you-dont-get-what-you-pay-for
Yes, True graphene is one layer. There are companies making a few layered graphene and that´s good enough. My question is why i get a different result than the video, either what I have is far from graphene or the method is false or I made a mistake in my experiment, something I don't see nor understand.
The guy in the video has no idea what he's talking about. Raman does not give mixed results; it is definitive. The easiest and cheapest way to know if you got graphene is to put it on a glass slide and observe whether you're getting the 2.3% broadband optical absorbance that is characteristic of single layer graphene. Both vials in the video look like they're full of plain old powdered graphite (Graphite is gray and shiny; graphene dispersed in a solvent is very light gray, and even then it's a mixture of few-layer and multilayer). In fact, at the end of the video, the guy says that it's probably 20-50 layers, which is really just graphite. It's not a matter of getting close with graphene: single-layer graphene has a fundamentally different electronic structure from even bilayer graphene.
Likes Magnetosphere
This is a known problem in the community. Graphene oxide is generally ok, but waaaaay overpriced (you can make it yourself in a few hours with sulfuric acid and permanganate). The CVD graphene for sale is usually garbage, which is surprising because it's not overwhelmingly difficult to make (in a lab; it would be quite challenging for a hobbyist--though I'm working on some atmospheric pressure methods now that a diligent hobbyist might be able to handle). I've never made the silicon carbide-derived graphene, but it's generally of lower quality than good CVD graphene and besides, there aren't really any good commercial sources of SiC graphene.
Likes Magnetosphere
Thanks for the input, interesting information regarding raman. When I speak of graphene I guess what I mean is a few layered graphite. None the less, the method he is mentioning does produce an interesting phenomena and there is a clear difference between his "graphene" and his graphite.
Have you seen Robert Murrays videos on making graphene? He first exfoliates grafoil and then sonicates it. I have tried it myself and I got what looked like graphite "graphene" nano particles that behaved and looked much different than before sonication. Anyway, the method in the video, is it viable?
Sonication in a well-chosen solvent is an established way of getting few-to-single layer graphene. Jonathan Coleman's group at Trinity College Dublin did the pioneering work on this about 10 years ago:
https://www.nature.com/articles/nnano.2008.215
I've done it myself: take a small amount of graphite and sonicate it for a few hours in NMP or DMF. You get a reasonable fraction of single layer graphene, but there's still a mixture. Other folks chemically intercalate species between the graphene layers to expedite exfoliation (this can be done with a number of other 2D materials as well). This usually works better, and it has the added bonus that, if you choose your intercalation conditions wisely, you can preferentially get monolayer, bilayer, trilayer, etc. Michael Strano's group at MIT did some work in this area:
https://www.nature.com/articles/nnano.2011.94
Likes jim mcnamara
Magnetosphere said:
When I speak of graphene I guess what I mean is a few layered graphite. .
Once you get to a "few layers" is it is pretty much just graphite and will have none of the interesting properties of graphene. For most applications you really do need single (mostly) layer graphene with maybe some fraction of two-layers.
There are various ways of checking if it is really is graphene, but none of them are -AFAIK- done using chemical methods; you really do need some form of specroscopy (Raman) or possible SPM (e.g. STM).
Related to Simple method for testing graphene
1. What is graphene?
Graphene is a thin layer of pure carbon, just one atom thick. It is a two-dimensional material with unique properties, such as high strength, flexibility, and electrical conductivity.
2. What is the simple method for testing graphene?
The simple method for testing graphene is called Raman spectroscopy. This method involves shining a laser onto the graphene sample and analyzing the scattered light to determine the properties of the graphene.
3. Why is it important to test graphene?
Testing graphene is important because it allows scientists to understand its properties and potential applications. By testing graphene, we can identify its strengths and weaknesses and find ways to improve its performance.
4. Can the simple method for testing graphene be used for other materials?
Yes, Raman spectroscopy can be used to test other two-dimensional materials as well, such as graphene oxide, molybdenum disulfide, and boron nitride. It is a versatile and widely used technique in materials science.
5. Are there any limitations to the simple method for testing graphene?
While Raman spectroscopy is a simple and non-destructive method for testing graphene, it does have some limitations. For example, it may not be able to detect defects in the graphene structure or provide information about the quality of the graphene sample.
  • Materials and Chemical Engineering
  • DIY Projects
  • Biology and Medical
15K
