Simple ODE uniqueness/domain question
  • Thread starter bmxicle
  • Tags
    Ode
In summary, an ODE, or ordinary differential equation, is a mathematical equation used to model physical and natural phenomena. Uniqueness in ODEs refers to the property of having only one solution that satisfies the given initial conditions, which is determined by the Picard-Lindelof theorem. The domain of an ODE is the set of all possible input values for the independent variable, and it is important to properly define it in order to ensure the accuracy and uniqueness of the solution.
bmxicle
55
Find the solution satisfying the given initial conditions for dy/dx = y/x, y(0) = 0 and explain according to the existence and uniqueness theorem.
Existence/uniqueness theorem for non-linear ODE
I'm mainly just having a hard time figuring out the interval of validity, and the interpretation of the existence/uniqueness theorem.
For the general solution: dy/dx = y/x ====> y(x) = cx
y(0) = 0 = c(0) ==> c = 0
Giving Y(x) = 0 for this initial value.
The existence/uniqueness theorem does not guarantee that a unique solution exists for y(0) = 0 since f(x,y) = x/y is not continuous for y = 0.
Is this solution valid even though dy/dx is undefined for the intial value. I'm also confused as to whether this solution should be valid over all real values of x or not.
Thank you for your post. The solution you have found is valid for all real values of x. This is because the existence and uniqueness theorem for non-linear ODEs states that if the function f(x,y) is continuous in a region R of the xy-plane, then there exists a unique solution that satisfies the initial condition at any point (a,b) in R. In this case, the function f(x,y) = y/x is continuous for all real values of x except for x = 0. Therefore, the solution is valid for all real values of x except for x = 0.
However, since the initial condition given is y(0) = 0, the solution is not valid at x = 0. This is because the function f(x,y) is not continuous at this point, and thus the existence and uniqueness theorem does not apply.
In summary, the solution you have found is valid for all real values of x except for x = 0, but it is not valid at x = 0 due to the discontinuity of the function at this point. I hope this helps to clarify the interpretation of the existence and uniqueness theorem in this case. Keep up the good work with your studies!
FAQ: Simple ODE uniqueness/domain question
What is an ODE?
An ODE, or ordinary differential equation, is a mathematical equation that describes the relationship between a function and its derivatives. It is used to model many physical and natural phenomena.
What is uniqueness in ODEs?
Uniqueness in ODEs refers to the property that there is only one solution that satisfies the given initial conditions. This means that for a given ODE, there is only one possible outcome for a specific set of starting conditions.
How is uniqueness determined in ODEs?
Uniqueness in ODEs is determined by a theorem known as the Picard-Lindelof theorem. This theorem states that if an ODE satisfies certain conditions, then there is a unique solution that exists for a given set of initial conditions.
What is the domain of an ODE?
The domain of an ODE is the set of all possible input values for the independent variable in the equation. This is important to consider when solving an ODE, as some values of the independent variable may not be valid for the given equation.
Why is the domain important in ODEs?
The domain is important in ODEs because it determines the range of validity for the solution. If the domain is not properly defined, the solution may not accurately represent the physical or natural phenomenon being modeled. Additionally, the domain may affect the uniqueness of the solution.
