Simple open set topology question
In summary, the concept of a set being open, closed, both or neither depends on how the topology is defined. In some topologies, a set with bounds can be considered open. However, in other topologies, the same set may be considered closed. The discrete topology defines every subset as open, making them simultaneously open and closed.
SYoungblood
64
[/B]
Is {n} an open set?
[/B]
To use an example, for any n that is an integer, is {10} an open set, closet set, or neither?
[/B]
I say {10} is a closed set, because it has upper and lower bounds right at 10; in other words, it is both open and closed on the number line right at 10.
However, I believe the compliment of {10}, (-inf, 10) u (10, inf) is an open set.
I'm just starting to learn basic topology, thank you for any help that you can offer.
SY
Whether a set is closed, open, both or neither depends on how the topology is defined. A topology is basically exactly that: say which subsets are open (or likewise closed). E.g. a set with a single element is always open in the discrete topology in which all subsets are considered open. It is not open, if we consider, e.g. the topology of the reals induced by the Euclidean metric, the norm topology.
My topology book hasn't talked about discrete topology (yet, it's still early on in the course).
How could it be open if the set has bounds like the compliment given above?
Thank you,
SY
Thank you,
SY
Perhaps a supporting example -- we have (0,1) as an open set, while [0,1] is a closed set. Both (0,1] and [0,1) are neither open nor closed.
If you simply define every subset to be open, then all subsets are simultaneously open and closed. It is how the discrete topology is defined. As long as the conditions for a topology hold, you can define various topologies on the same set ##X##. The discrete topology is the finest possible, the topology ##\{\emptyset\, , \,X\}## the coarsest.
This is true, if you consider the topology which is defined by the metric, i.e. the distance between points, where the open sets are ##U_r(p)=\{q \in \mathbb{R}\,\vert \, d(p,q) = |p-q| < r\}## and their unions.
Likes SYoungblood
Thank you,
SY
Related to Simple open set topology question
What is a simple open set topology?
Simple open set topology is a mathematical concept that deals with the properties and structure of open sets in a topological space. It is a fundamental part of point-set topology and is used to study the properties of continuous functions and topological spaces.
What is the difference between open sets and closed sets?
An open set is a set that contains all its boundary points, while a closed set is a set that contains all its limit points. In other words, an open set does not include its boundary points, while a closed set does.
What is the definition of a simple open set?
A simple open set is a set that is both open and connected. This means that it is a subset of a topological space that does not contain any of its boundary points and cannot be divided into two disjoint non-empty open subsets.
How is simple open set topology used in real-world applications?
Simple open set topology has many applications in various fields, such as physics, engineering, and computer science. It is used to study the behavior of continuous systems, analyze networks and data structures, and model the dynamics of physical systems.
What are some common properties of simple open sets?
Some common properties of simple open sets include being connected, being path-connected, and being locally connected. They also have the property of being dense in the topological space, meaning that they are very "close" to each other.
