MHB Simple pendulum with air resistance
The discussion revolves around solving mechanics homework related to a simple pendulum affected by air resistance. The user is attempting to derive the equation of motion for small angular displacements and is unsure about incorporating air resistance into their calculations. A participant provides corrections to the user's formulas for acceleration and total force, emphasizing the need to apply Newton's second law correctly. The conversation highlights the importance of approximations in simplifying the equations and clarifies the user's confusion regarding the application of fundamental physics principles. Overall, the exchange aids in refining the user's understanding of the problem.
Carla1985
Im getting stuck on a couple of the questions for my mechanics homework. Il put what I've done so far and hopefully someone can check I am doing it right n push me into the right direction for the rest.
"A grandfather clock has a simple pendulum of length L with a bob of mass m. The effect of air resistance is to produce a force on the bob of magnitude 2cm times its speed, where c > 0 is a positive constant.
(i) Show that, provided the angular displacement θ of the pendulum from the downward vertical is small, θ approximately satisfies the equation,
\ddot{\theta}+2c\dot{\theta}+\frac{g}{L}\theta=0
[Hint: Use polar coordinates and Taylor’s theorem as we did in lectures for the case without air resistance.]
(ii) Suppose now that c = $\sqrt{g/L}$. Show that if $\theta(0) = a$ and $\dot{\theta}(0) = 0$, then
$\theta(t) = a(1 + ct)e^{−ct}$
Will the pendulum ever return to the vertical position in this case? Explain
your answer"
so far I have:
The rod has fixed length r=L so
$\vec{r}=L\vec{e}_r$
as r=L is a constant, $\dot{r}=\ddot{r}=0$
so acceleration is
$\ddot{r}=(\dot{r}-r\dot{\theta}^2)e_r+(2\dot{r}\dot{\theta}+r\ddot{\theta})e_\theta$
$=-L(\dot{\theta}^2e_r+L\ddot{\theta}e_\theta$
so the total force is
$(mgcos\theta-T)e_r-(mgsin\theta+2cm\dot{x})e_\theta$I've completed a very similar question without air resistance without too much problems but not sure if I've added air resistance in right at all. Hope it at least makes some sense :/
Thanks
Mathematics news on Phys.org
Carla1985 said:
so far I have:
so acceleration is
Thanks
Hi Carla1985! :)
Actually, if I'm nitpicking a bit, your formula for acceleration should be:
$$\ddot{\mathbf{\vec r}}=(\ddot{r}-r\dot{\theta}^2)\mathbf{\vec e_r} + (2\dot{r}\dot{\theta}+r\ddot{\theta})\mathbf{\vec e_\theta} = -L\dot{\theta}^2\mathbf{\vec e_r} + L\ddot{\theta}\mathbf{\vec e_\theta}$$
And your total force should be:
$$\mathbf{\vec F} = (mg\cos\theta-T)\mathbf{\vec e_r}-(mg\sin\theta+2cm \cdot L\dot{\theta})\mathbf{\vec e_\theta}$$
Since each of the components of $\mathbf{\vec F}$ must be equal to each of the components of $m\ddot{\mathbf{\vec r}}$ (Newton's 3rd law), you get:
$$\left\{\begin{array}{lll}
mg\cos\theta-T &=& -mL\dot{\theta}^2\\
mg\sin\theta+2cm \cdot L\dot{\theta} &=& mL\ddot{\theta}
\end{array}\right.$$
Furthermore, you can use the approximation $\sin \theta \approx \theta$.So where are you stuck?
Actually your few alterations put me back on track, surprising how silly mistakes can confuse the whole thing. Thank you very much :D
I like Serena said:
Since each of the components of $\mathbf{\vec F}$ must be equal to each of the components of $m\ddot{\mathbf{\vec r}}$ (Newton's 3rd law), ...
Did you mean Newton's 2nd Law?
Yep.
Thanks for spotting that.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
