Simple problem concerning R[x], R and a prime ideal I
  • MHB
  • Thread starter Math Amateur
  • Tags
    Prime
In summary: P, and one of a or b is not in PcapR, then, according to the definition of a prime ideal, P is not a prime ideal.I think I understand the clarification now.In summary, Dummit and Foote state that if a prime ideal in a ring R is also a prime ideal in R[x], then P is a prime ideal in R. However, this is not always the case, and must be confirmed.
Math Amateur
MHB
3,998
48
I am reading Dummit and Foote Section 15.4: Localization.
On page 710, D&F make the following statement:
"In general, suppose R is a commutative ring. If P is a prime ideal in R[x] then \(\displaystyle P \cap R \) is a prime ideal in R ... ..."
In checking out the validity of this assertion I wish to reason the following way:
Elements of \(\displaystyle P \cap R \) must be constant terms in P of the form \(\displaystyle a,b \in R\).
Given this, we reason as follows:
\(\displaystyle ab \in P \cap R \Longrightarrow ab \in P \) and \(\displaystyle ab \in R \)
Now \(\displaystyle ab \in P \Longrightarrow a \in P \) or \(\displaystyle b \in P \) since P is a prime ideal ... ... ... (1)But we also have that:
\(\displaystyle ab \in R \Longrightarrow a \in R \) and \(\displaystyle b \in R \) ... ... ... (2) [... ? but why exactly ... does this actually follow from the closure of multiplication ... or not ?]
Then I wish to claim that (1) and (2) give me the following:
\(\displaystyle ab \in P \cap R \Longrightarrow a \in P \cap R \) or \(\displaystyle b \in P \cap R \)
Can someone please confirm that this reasoning is correct?
My problem or uncertainty is with my claim in the above that:
\(\displaystyle ab \in R \Longrightarrow a \in R \) or \(\displaystyle b \in R \)
I am not sure how to justify this reasoning.
I would appreciate a clarification.
Peter
You don't have to show (2).
To show $P$ (in an arbitrary ring $R$) is a prime ideal, you show that for any $a,b \in R$ such that $ab \in P$, that one of $a,b \in P$.
In other words, we already have, by assumption that $a,b \in R$. We can assume (why?) that for $ab \in P \cap R$, that $a \not\in P \cap R$.
Since $a$ is already GIVEN to be an element of $R$, the only way it can fail to be in $P \cap R$ is if $a \not \in P$ (here we are considering $a$ as belonging to two rings:
the first is as an element of $R$, and the second is as an element of the embedding of $R$ (as constant polynomials) in $R[x]$).
Since $a$ (as an element of $R[x]$) is not in $P$, and since $ab$ (as likewise an element of $R[x]$) IS in $P$, and $P$ is prime, we must have $b \in P$.
But $b$ is also given as belonging to $R$, so $b \in P \cap R$, showing $P \cap R$ is a prime ideal of $R$.
Thanks for the help Deveno.
But, just one further clarification ... you write:
"To show $P$ (in an arbitrary ring $R$) is a prime ideal, you show that for any $a,b \in R$ such that $ab \in P$, that one of $a,b \in P$."
The definition of a prime ideal (D&F page 255) is as follows:
Definition. Assume R is commutative. An ideal P is called a prime ideal if \(\displaystyle P \ne R \) and whenever the product of ab of two elements \(\displaystyle a, b \in R\) is an element of P, then at least one of a and b is an element of P.
Now I am assuming that since the definition of a prime ideal P reads "at least one of a and b is an element of P" that we may have the possibility of both elements being contained in P.
Thus I am having trouble following you when you write:
"In other words, we already have, by assumption that $a,b \in R$. We can assume (why?) that for $ab \in P \cap R$, that $a \not\in P \cap R$."
if the situation is that both a and b may be in P, how can we assume that $a \not\in P \cap R$?
Can you help?
Peter
A more complete elaboration goes as follows:
Suppose $a,b \in R$ are such that: $ab \in P$.
If we wish to prove $P$ is prime, we must show that one (or both) of $a,b \in P$.
If $a \in P$, there is nothing to prove.
Thus, we may assume without loss of generality that $a \not \in P$.
(For if $a \in P$ for any such $a$, then $P$ is prime).
In this case, to prove $P$ prime, we must show $b \in P$.
In a more familiar setting:
suppose we have INTEGERS $a,b$ such that $ab = pd$ for some prime integer $p$.
Clearly, $p$ divides $pd$, which means $p$ divides $ab$ (since these are equal).
If $p$ divides $a$, then clearly $a = kp$, that is: $a \in P = (p)$.
If $p$ does NOT divide $a$, then we must have (by the primality of $p$, by definition) $p$ divides $b$.
We have 4 possible cases:
$p|a,p|b$
$p|a,p\not\mid b$
$p \not\mid a,p|b$
$p \not\mid a,p\not\mid b$
The case we want to rule out is the last one. To rule it out, assume $p$ doesn't divide one of them (it doesn't really matter which one, $a$ comes first, and by commutativity of multiplication in integers we can switch their roles). Then we want to show the NEGATION of:
$p\not\mid b$
which is, of course, the same as showing $p|b$.
I hope this helps.
$p|a,p|b$
$p|a,p\not\mid b$
$p \not\mid a,p|b$
$p\not\mid b$
I hope this helps.
You write: "I hope this helps"
Indeed, most definitely helpful, Deveno.
Thank you.
Peter
FAQ: Simple problem concerning R[x], R and a prime ideal I
What is R[x], R, and a prime ideal I in this context?
R[x] is the polynomial ring over a commutative ring R, where the elements are polynomials with coefficients in R. R is a commutative ring with identity, and a prime ideal I is a proper subset of R that is closed under addition and multiplication, and satisfies the property that if ab is in I, then either a or b is in I.
How does R[x] differ from R?
R[x] includes all possible polynomials with coefficients in R, while R only includes the elements of the ring itself. R[x] is also a larger ring than R, as it contains all the elements of R and additional elements in the form of polynomials.
What is the significance of a prime ideal in this problem?
Prime ideals play an important role in understanding the structure of rings. In this problem, a prime ideal I can help determine whether a polynomial in R[x] can be factored into irreducible polynomials, and can also provide insight into the factorization of elements in R.
How can R[x] and R be used to solve a simple problem concerning a prime ideal?
R[x] and R can be used to determine whether a polynomial in R[x] is irreducible by checking if it is in a prime ideal I. Additionally, these structures can also be used to factor elements in R, as the prime ideal I can provide information about the irreducible factors of a given element.
Can you provide an example of a simple problem concerning R[x], R, and a prime ideal I?
One example could be finding the prime factorization of a polynomial in R[x]. By identifying the prime ideal I that the polynomial belongs to, we can then use the structure of R and the properties of prime ideals to factor the polynomial into irreducible elements.
