MHB Simple Problem - Establishing an Isomorphism
  • Thread starter Thread starter Math Amateur
    Isomorphism
Math Amateur
MHB
In Example 7 in Dummit and Foote, Section 10.4. pages 369-370 (see attachment) D&F are seeking to establish an isomorphism:
$$ S \otimes_R R \cong S $$
They establish the existence of two S-module homomorphisms:
$$ \Phi \ : \ S \otimes_R R \to S $$
defined by $$ \Phi (s \otimes r ) = sr $$
and
$$ {\Phi}' \ : \ S \to S \otimes_R R $$
defined by $$ {\Phi}' (s) = s \otimes 1 $$D&F then show that $$ \Phi {\Phi}' = I $$ where I is the identity function on simple tensors ...
How does this establish that $$ S \otimes_R R \cong S $$ ... presumably this establishes $$ \Phi $$ as a bijective homomorphism ... but how exactly ...
Peter
A bijective homomorphism is also called an isomorphism...
To be a bit more clear, let us suppose we have two $R$-module homomorphisms:
$f:M \to N$
$g: N \to M$
such that $g \circ f = 1_M$, the identity map on $M$.
Claim 1: $g$ is surjective.
Let $m \in M$. Then $m = g(f(m))$ so that $m$ has the pre-image under $g$ of $f(m)$.
Claim 2: $f$ is injective.
Suppose $f(m) = f(m')$. Then $m - m' = g(f(m)) - g(f(m')) = g(f(m) - f(m')) = g(0) = 0$, so $m = m'$.
Now, if we already know $f$ is surjective, this means $f$ is bijective, hence an isomorphism (and $g$ is also likewise an isomorphism).
Since any $s \in S$ has the pre-image (under $\Phi$) $s \otimes 1$, $\Phi$ is clearly surjective.
By showing $\Phi'\Phi$ is the identity on simple tensors, it follows from the bilinearity of $\otimes$ that it is the identity on any SUM of simple tensors, that is, on any tensor.
(it should be clear that the identity map $I$ on $S\otimes_R R$ is indeed an $S$-linear map).
(EDIT: you have the composition order of $\Phi$ and $\Phi'$ reversed)
(EDIT #2: D&F also show that $\Phi\Phi' = 1_S$ which means these morphisms are two-sided inverses of each other, hence each is a bijection).
The world of 2\times 2 complex matrices is very colorful. They form a Banach-algebra, they act on spinors, they contain the quaternions, SU(2), su(2), SL(2,\mathbb C), sl(2,\mathbb C). Furthermore, with the determinant as Euclidean or pseudo-Euclidean norm, isu(2) is a 3-dimensional Euclidean space, \mathbb RI\oplus isu(2) is a Minkowski space with signature (1,3), i\mathbb RI\oplus su(2) is a Minkowski space with signature (3,1), SU(2) is the double cover of SO(3), sl(2,\mathbb C) is the...
