Simple rate of change problem?
In summary: That's essentially what you did in your first post, but you need to take the limit at the end to get the derivative.
physphys
23
The Function S(t) = 6t(t+1) describes the distance (in kilometers) that a car has traveled after a time t ( in hours), t E [0,6]
Find the average velocity of the car from t= 2 to t= 2 + ∆t
y'= f(x+h) - f(x)
h
I know from the power rule that the derivative of this function is 12t + 6
however when I try to use the rate of change formula I get 6t+ 20
Here is my work
s(t)' = s(2 + ∆t) - s(2)
∆t
=6(2+∆t)(∆t+2+1) - 36
∆t
= (12+ 6∆t)(∆t+3) -36
∆t
= 12∆t + 36 + 6∆t^2 + 18t - 36
∆t
=6∆t^2 + 30t
∆t
= 6t + 30
So where did I go wrong?
y'= f(x+h) - f(x)
h
Here is my work
∆t
∆t
∆t
∆t
=6∆t^2 + 30t
∆t
= 6t + 30
You didn't do anything wrong except for some typos and you changed Δt into t. You should get 6Δt+30. To compare that with the derivative you need to let Δt->0. So the derivative S'(2) should come out to 30. If you put t=2 into the derivative you computed, 12t+6, you'll get the same number.
y'= f(x+h) - f(x)
h
Here is my work
∆t
∆t
∆t
∆t
=6∆t^2 + 30t
∆t
= 6t + 30
S(t) = 6*t^2 + 6*t, so the instantaneous velocity is v(t) = dS(t)/dt = 12*t + 6, and for small Δt > 0 that will also be the average velocity over [t,t+Δt]. For t = 2 this gives average_velocity = 24 + 6 = 30 (km/hr). Your error was in writing 12Δt + 18Δt as 12Δt + 18t.
oh okay I see, for some reason I thought using the first principle and finding Y' would give me the derivative, however, it just gives me the rate of change. Thanks for helping!
Right. You can get the derivative from what you did by replacing 2 with t, working through the algebra again and then taking the limit as Δt->0.
Related to Simple rate of change problem?
1. What is the definition of "simple rate of change"?
The simple rate of change, also known as the average rate of change, is a measure of how much a quantity changes over a specific period of time.
2. How do you calculate the simple rate of change?
The simple rate of change can be calculated by finding the difference between the initial and final values of a quantity, and then dividing that difference by the amount of time that has passed.
3. What is the purpose of solving a simple rate of change problem?
The purpose of solving a simple rate of change problem is to understand and quantify the rate at which a quantity is changing, which can be useful in analyzing trends and making predictions.
4. What are some real-world applications of simple rate of change?
Simple rate of change can be applied in various fields such as economics, physics, and biology. For example, it can be used to calculate the average speed of a moving object, the growth rate of a population, or the rate of change of stock prices.
5. Is there a difference between simple rate of change and average rate of change?
No, simple rate of change and average rate of change refer to the same concept and can be used interchangeably.
