A Simple S matrix example in Coleman's lectures on QFT
Glenn Rowe
TL;DR Summary
In Coleman's QFT lectures, I'm confused by equation 7.57. To give the background, Coleman is trying to calculate the scattering matrix (S matrix) for a situation in which the Hamiltonian is given by
$$H=H_{0}+f\left(t,T,\Delta\right)H_{I}\left(t\right)$$
where ##H_{0}## is the free Hamiltonian, ##H_{I}## is the interaction, and ##f## is a function that turns the interaction on only for a time interval ##T## around ##t=0##. ##\Delta## determines the rate at which the interaction is switched on and off.
Since the interaction is off for times in the distant past and future, the state at these times will be the exact state determined by the free Hamiltonian ##H_{0}##. Coleman calls this state (for the distant past) ##\left|\psi\left(-\infty\right)\right\rangle ^{\text{in}}## and claims that it is given by
$$\left|\psi\left(-\infty\right)\right\rangle ^{\text{in}}=\lim_{t^{\prime}\rightarrow-\infty}e^{iH_{0}t^{\prime}}e^{-iHt^{\prime}}\left|\psi\right\rangle =\lim_{t^{\prime}\rightarrow-\infty}U_{I}\left(0,t^{\prime}\right)\left|\psi\right\rangle $$
where ##U_{I}## is the evolution operator in the interaction picture. He doesn't specify what the state ##\left|\psi\right\rangle## is, but I can't make sense of this equation no matter what I assume about it. Is it the state in the Schrodinger picture or the interaction picture? What time is the state supposed to be at?
If it's the Schrodinger picture (as seems to be the case, as he says this when calculating ##S## in equation 7.59) and the time is ##t=0##, then the ##e^{-iHt^{\prime}}## operator would evolve the state to time ##t^{\prime}##, but then what is the additional ##e^{iH_{0}t^{\prime}}## for?
Finally, how does he get the last equality above? According to Coleman's definition of ##U_{I}## (his equation 7.31) we should have
$$U_{I}\left(t,0\right)=e^{iH_{0}t}e^{-iHt}$$
where the ##t## and the 0 are swapped from its occurrence in the above equation.
Anyone have any thoughts? Thanks.
I hope Coleman didn't really mean that ##f## is a step function, because then he's generally in big trouble. I don't believe that Coleman really made such a claim. It's really important to do this right and introduce "adiabatic switching" as Gell-Mann and Low did to define the S-matrix in a consistent way. A very good explanation in the QFT context is given in Bjorken and Drell, Quantum Field theory.
Likes Demystifier
What exactly goes wrong if one takes a step function?
Have a look at this:
https://arxiv.org/abs/1310.5019
I think this is a nice example underlining the importance of a correct and smooth "adiabatic switching" (both on and off!) in QFT.
I ordered Coleman's book, because this must simply be a gem. Unfortunately it'll take more than 4 weeks to arrive :-(.
I found some other lecture notes from Coleman's QFT lectures online
https://arxiv.org/abs/1110.5013
There it's of course correct and very well discussed, as expected.
Likes Demystifier and physicsworks
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
I am reading WHAT IS A QUANTUM FIELD THEORY?" A First Introduction for Mathematicians. The author states (2.4 Finite versus Continuous Models) that the use of continuity causes the infinities in QFT: 'Mathematicians are trained to think of physical space as R3. But our continuous model of physical space as R3 is of course an idealization, both at the scale of the very large and at the scale of the very small. This idealization has proved to be very powerful, but in the case of Quantum...
Thread 'Lesser Green's function'
The lesser Green's function is defined as: $$G^{<}(t,t')=i\langle C_{\nu}^{\dagger}(t')C_{\nu}(t)\rangle=i\bra{n}C_{\nu}^{\dagger}(t')C_{\nu}(t)\ket{n}$$ where ##\ket{n}## is the many particle ground state. $$G^{<}(t,t')=i\bra{n}e^{iHt'}C_{\nu}^{\dagger}(0)e^{-iHt'}e^{iHt}C_{\nu}(0)e^{-iHt}\ket{n}$$ First consider the case t <t' Define, $$\ket{\alpha}=e^{-iH(t'-t)}C_{\nu}(0)e^{-iHt}\ket{n}$$ $$\ket{\beta}=C_{\nu}(0)e^{-iHt'}\ket{n}$$ $$G^{<}(t,t')=i\bra{\beta}\ket{\alpha}$$ ##\ket{\alpha}##...
