Simple Significant Figure Problem
  • Thread starter BillhB
  • Tags
    Figure
In summary: I don't think it is rash at all. It is a simple fact that rounding can lead to accumulation of errors. A simple example is if you have a sequence of calculations that involve rounding, the errors from each round can accumulate and result in a significantly different value from the original. This can be especially problematic in long calculations with multiple steps. Additionally, if you round too early in a calculation, you may lose precision and end up with a less accurate result.
BillhB
35
Convert ##120. \frac{km}{h}## to ##\frac{m}{s}##
##1 km=10^3 m##
##1 hour = 3600 seconds##
Not so much concerned with the solution, it's easy, as to what happened after the solution was found. So you get ##33.33\overline{33}##, after which the professor rounded to 33.3 citing significant figures. That makes no sense though, if we go back in the other direction we would see this new value is actually ##119.88\frac{km}{h}## which is more precise than the original value. If you used this value in another calculation it seems like it would defeat the entire purpose of doing the whole silly significant figure thing in the first place.
Now you could just cite significant figures again and get back to 120., but if you wanted to convert the value into use again at a later date you'd have rounding error. The chemistry lecture professor basically brushed me off when I brought it up. I was arguing that the entire ##33\frac{1}{3}## was significant.
Who's right? Any insights here?
I believe the decimal point shown in "120." says the 0 is a significant figure (not sure how it works if it had been 1200 with three sig figs). This means you should take the exact value as being anywhere in the range 119.5 to 120.5. On dividing by 3.6 that gives 33.2 to almost 33.5, so even quoting 33.3 (implying 33.25 to 33.35) is overexact. But hey, there's only so much you can do without quoting specific bounds.
Give your prof a break.
Likes BillhB
BillhB said:
...if we go back in the other direction we would see this new value is actually 119.88 km/h which is more precise than the original value.
I believe you add one or two more significant figures when you run the computation backwards.
(e.g. 33.333) That prevents imprecision from compounding.
But you still round the final answer off to 3 significant figures when you're done.
Likes SammyS
This ain't really helpful.
Probably use scientific notation? I would guess.
I should have said so, my bad, but the class generally assigns the last digit as the uncertain one and puts the error bounds at ##\pm 1##, so 119 to 121 km. That's another convention that doesn't seem very logical to me. If I were to use a measuring device with increments in which I would guess at a whole kilometer, I don't see how I could possibly be an entire kilometer off in either direction. This seems like it would true for any measurement that's around everyday units. ##\pm .5## makes a lot more sense. End rant.
So on dividing by 3.6 we would get ##33+\frac{1}{18}## to ##33 + \frac{11}{18}##, so I just think we should keep the ##33 + \frac{1}{3}## and specify a new uncertainty of ##\pm\frac{5}{18}## to propagate both the precision and uncertainty correctly of the original measurement.
Would this be right?
It would be easier if the professor didn't say other things which made no sense, like accuracy of measuring devices isn't important, only precision is. She went on to say they pay 2000 dollars for each digit after the decimal, and I told her I would sell her a scale that had ##10^{whatever}## precision for 2 grand a digit, but wasn't accurate at all if that's what she thought. Maybe she brushed me off because I came across like a dick, but I only wanted to illustrate the silliness of the statement.
Last semester the professor in the same department said similar things, but was actually worse. He gave me a F on one exam because I didn't round after each step in a calculation. I tried to explain that's not how it works, and eventually had to go to the dean. He hated me the rest of the course, possibly because I made him look like an idiot in front of the dean.
I don't think he was an idiot, he had a Ph.D in chemistry, I just don't feel like they care or think we as students are too dumb to learn things the correct way. Maybe we are, but try me first before preaching something that seems error ridden.
I just want to learn things the correct way, it's frustrating when none of my science courses can agree on how to handle the math in science. At least the physics courses generally treat this stuff better, it makes me question my desire to be a doctor and continue with this chemistry department. end second rant.
That prof gets an F from me. I regularly have occasion on these forums to point out that rounding prematurely leads to accumulation of errors. By the time you're done you might have no precision left.
BillhB said:
keep the ##33+\frac{1}{3}## and specify a new uncertainty of ##\pm\frac{5}{18}##
You should keep it in decimals. Taking the original to be +/-1 (ugh) that gives 33.3+/-0.3.
Likes BillhB
Got it, thank you so much for the help and for letting me vent.
This is a rather rash statement ! Can you quote some of your regular occasions when you have pointed this out (save me searching)
Do you mean precision or accuracy?...is it better to be precise or accurate?
'Insignificant figures never become significant figures'
This looks to me like it would be very helpful.
It just wasn't useful to the question that I was asking. I had already said in the post that you can get back to 120. using significant figures again.
The question was more along the lines as to what the proper answer would be that maintained the precision of the original measurement. The rounding to the significance of the original measurement bothered me for that reason, because it was technically more precise than the original measurement with identical error bounds... ##\pm1## That's why I thought it best to just give the fractional answer with fractional uncertainty that covered the entire range and maybe with a caveat that either gave the original significance of the measurement or the original measurement itself.
Practically, if I were going to use the value in the future in another calculation which would include going back to the original measurement I would just use the entire fractional value. Rounding at the end.
In the end, if the question is just a conversion type problem, I'll keep it in decimals, rounded to the significance of the original measurement, with the best new uncertainty as possible.
Yes, that is the right approach - or, at least, to keep a few extra digits of precision until the end.
You should also be aware that when intermediates are irrational you may be forced to round them, and this might still lead to less precision than you think. E.g. a careless attack on π-22/7.
Related to Simple Significant Figure Problem
1. What are significant figures and why are they important in scientific calculations?
Significant figures are the digits in a number that carry meaning and contribute to the precision of a measurement or calculation. They are important because they indicate the level of accuracy and reliability of a number, and help ensure that calculations are performed correctly and consistently.
2. How do you determine the number of significant figures in a given number?
The rules for determining significant figures are as follows:- Non-zero digits are always significant.- Any zeros between two significant digits are significant.- Leading zeros are not significant.- Trailing zeros after a decimal point are significant.- Trailing zeros before a decimal point may or may not be significant, depending on the context.
3. Can significant figures be used in addition and subtraction?
Yes, significant figures can be used in addition and subtraction. The final result should have the same number of decimal places as the number with the least number of decimal places in the calculation.
4. How do you round a number to the correct number of significant figures?
To round a number to the correct number of significant figures, follow these steps:1. Identify the last significant digit in the number.2. Look at the next digit to determine if it should be rounded up or down.3. If the next digit is 5 or greater, round up the last significant digit.4. If the next digit is less than 5, leave the last significant digit as is.5. Replace all digits after the last significant digit with zeros.
5. Can significant figures be used in multiplication and division?
Yes, significant figures can be used in multiplication and division. The final result should have the same number of significant figures as the number with the least number of significant figures in the calculation.
