Simple torsional stress question
  • Thread starter Thread starter kubedgamer
    Stress
The discussion centers on the comparison of torsional stress in two configurations of motor-impeller connections. In the first setup, the motor is directly connected to the impeller, while in the second, it uses bevel gears at a 90-degree angle. It is suggested that the gears do not significantly reduce torsional stress on the motor, despite adding some inertia to the system. Participants recommend conducting a personal analysis of the system by deriving equations of motion and calculating stresses for a clearer understanding. Overall, the conclusion is that the gears do not provide a meaningful reduction in stress on the motor.
kubedgamer
I am having trouble understanding a relatively simple concept.
A motor is connected to an impeller directly. i.e Motor -> shaft -> impellers
A motor is also connected at 90* to an impeller/shaft i.e Motor -> small shaft -> bevel gears (as linked below) -> shaft -> impellers
http://www.bandhgears.co.uk/images/bevel_gear_suppliers.gif
Will the torsional stress induced by a load on the impellers be better absorbed in the second instance by the gears thus putting less stress on the motor?
The gears will add a small amount of inertia to the system, but otherwise, the two are identical. There is no useful stress reduction achieved by the gears.
Thank you. Is there some sort of literature I can read about a proof for this?
Why not do your own analysis of the system? Write the equations of motion, draw the stress blocks on the shaft(s) and find the stresses for yourself. That will be the most convincing approach.
Had my central air system checked when it sortta wasn't working. I guess I hadn't replaced the filter. Guy suggested I might want to get a UV filter accessory. He said it would "kill bugs and particulates". I know UV can kill the former, not sure how he thinks it's gonna murder the latter. Now I'm finding out there's more than one type of UV filter: one for the air flow and one for the coil. He was suggesting we might get one for the air flow, but now we'll have to change the bulb...
  • · Replies 21 ·
12K
12K
