Simple Trigonometric Identities
In summary, if $\sin \Theta = 2/3$ and $\Theta$ is in the first quadrant, then $\sec \Theta = 3/\sqrt{5}$.
courtbits
If (sinΘ) = 2/3 with Θ in quadrant 1, find (secΘ)[/SIZE]
Θ = theta
Completely new at trigonometric identities, would be a great help!
Mathematics news on Phys.org
We have that $\sec (\theta)=\frac{1}{\cos (\theta)}$ and $\sin^2 (\theta)+\cos^2 (\theta)=1$.
Using these two identities we get:
$$\sec^2 (\theta)=\frac{1}{\cos^2 (\theta)}=\frac{1}{1-\sin^2 (\theta)}$$
So what exactly is the answer, is the answer the sec^2 Θ =? to all those other identities or is the rest to solve by me? o.o" I'm a dunce I know.
We are given that $\sin (\theta)=\frac{2}{3}$, so replacing this at the relation of post #2 we have:
$$\sec^2 (\theta)=\frac{1}{1-\sin^2 (\theta)}=\frac{1}{1-\left ( \frac{2}{3}\right )^2}=\frac{1}{1-\frac{4}{9}}=\frac{1}{\frac{9}{9}-\frac{4}{9}}=\frac{1}{\frac{5}{9}}=\frac{9}{5}$$
So, we have $\sec^2 (\theta)=\frac{9}{5}$.
To get the desired result, $\sec (\theta)$, you have to take the square root of the above equation.
so does that mean i square root sec^2(Θ) so that they eliminate and then i square root 9/5?
OR am I completely off? >~>"
Yes, you do the following:
$$\sec^2 (\theta)=\frac{9}{5} \Rightarrow \sqrt{\sec^2 (\theta)}=\sqrt{\frac{9}{5}} \Rightarrow \sec (\theta)=\pm \frac{3}{\sqrt{5}}$$
Yeah, I'm still completely confused. However, I will read this over and over again until I understand. Thank you very much on helping my empty brain. e.e"
Just a very minor quibble...since we are given that $\theta$ is a first quadrant angle, we then know to take the positive root. :)
MarkFL said:
Just a very minor quibble...since we are give that $\theta$ is a first quadrant angle, we then know to take the positive root. :)
Wow, that did leave a bit of confusion because I had be precise with my answer. Thank you!
Θ = theta
Hi courtbits,
Since $\Theta$ is a first quadrant angle and $\sin \Theta = 2/3$, $\Theta$ is an acute angle, so we can draw a right triangle with one of the angles $\Theta$ such that the side opposite $\Theta$ is $2$ and the hypotenuse is $3$ (recall sine = opposite/hypotenuse). By the Pythagorean theorem, the side adjacent $\Theta$ is $\sqrt{3^2 - 2^2} = \sqrt{9- 4} = \sqrt{5}$. So then $$\sec \Theta = \frac{\mathrm{hypotenuse}}{\mathrm{adjacent}} = \frac{3}{\sqrt{5}}$$
Make sure you draw the picture yourself to see what's going on. :D
FAQ: Simple Trigonometric Identities
What are simple trigonometric identities?
Simple trigonometric identities are equations that relate the basic trigonometric functions (sine, cosine, and tangent) to each other. They are used to simplify trigonometric expressions and solve equations involving angles.
What is the Pythagorean identity?
The Pythagorean identity is a simple trigonometric identity that states that the square of the sine of an angle plus the square of the cosine of the same angle is equal to 1. In other words, sin²θ + cos²θ = 1.
How do I use simple trigonometric identities to solve equations?
You can use simple trigonometric identities to simplify trigonometric expressions and make equations easier to solve. By substituting one expression for another using a trigonometric identity, you can often reduce the complexity of the equation and make it easier to solve.
What is the difference between a reciprocal and a quotient trigonometric identity?
A reciprocal trigonometric identity relates a trigonometric function to its reciprocal, such as secant and cosecant. A quotient trigonometric identity relates two trigonometric functions in a quotient form, such as tangent and cotangent.
Why are simple trigonometric identities important in real life?
Simple trigonometric identities are used in many applications, such as engineering, physics, and navigation. They allow us to calculate angles and distances in real-world situations, making them an essential tool in many fields.
