Simple vector-decomposition (fluid mechanics)
In summary, the author is discussing the net momentum flux through a surface element and how it relates to the force exerted on the fluid by short-range interactions with the fluid on the other side of the surface. The notation may be confusing, but the key point is that the momentum flux vector is not necessarily normal to the surface, and the component of the flux that is normal to the surface is what contributes to the force exerted on the fluid.
Niles
1,866
I am reading an introductory book on fluid mechanics (freely available on the WWW) and I came across this on page 10:
Consider an infinitesimal plane surface element, dS = ndS, located at point r. Here, dS is the area of the element, and n its unit normal. The fluid which lies on that side of the element toward which n points is said to lie on its positive side, and vice versa. The net flux of x-momentum across the element (in the direction of n) is πx · dS, which implies (from Newton’s second law of motion) that the fluid on the positive side of the surface element experiences a force πx ·dS in the x-direction due to short-range interaction with the fluid on the negative side.
I don't understand the underlined part. We have a force-vector πx, which we decompose to find the overlap with some surface element dS. Shouldn't the force entering dS be directed along dS, and not πx as the author claims?
Thanks in advance.
Thanks in advance.
It's hard to get past all this unusual notation, with the symbol n being used for two different things (momentum flux and normal), but I think I know what they are trying to say. Let [itex]\vec{N_x}[/itex] represent the net momentum flux (vector) through a surface of constant x. This momentum flux vector is not necessarily normal to the surface, since the fluid velocity is not necessarily normal to the surface. We can represent this momentum flux vector by:
[tex]\vec{N_x}=ρv_xv_x\vec{i_x}+ρv_xv_y\vec{i_y}+ρv_xv_z\vec{i_z}[/tex]
In this example, since the surface of interest is one of constant x, [itex]\vec{dS}=\vec{i_x}dS[/itex], the component of the momentum flux normal to the surface is [itex]ρv_xv_x\vec{i_x}[/itex], and the component of the momentum flux tangential to the surface is [itex]ρv_xv_y\vec{i_y}+ρv_xv_z\vec{i_z}[/itex].
Related to Simple vector-decomposition (fluid mechanics)
1. What is vector decomposition in fluid mechanics?
Vector decomposition in fluid mechanics is the process of breaking down a vector quantity into its component parts in order to better understand and analyze its behavior. This is particularly important in fluid mechanics, where multiple forces and velocities can act on a fluid particle at the same time.
2. How is vector decomposition used in fluid mechanics?
Vector decomposition is used in fluid mechanics to analyze the forces and velocities acting on a fluid particle in a specific direction. By breaking down the vector into its component parts, scientists can better understand the impact of individual forces and how they contribute to the overall behavior of the fluid.
3. What are the steps involved in vector decomposition for fluid mechanics?
The steps for vector decomposition in fluid mechanics include identifying the vector quantity, determining its direction and magnitude, and breaking it down into its component parts using trigonometric functions. The resulting components can then be analyzed separately to gain a better understanding of the overall behavior of the fluid.
4. Can vector decomposition be used for non-uniform fluid motion?
Yes, vector decomposition can be used for non-uniform fluid motion. In this case, the vector quantities would have varying magnitudes and directions at different points in the fluid, and the process of decomposition would be used to analyze and understand their behavior at each point.
5. What are the limitations of vector decomposition in fluid mechanics?
One limitation of vector decomposition in fluid mechanics is that it assumes the fluid is in a steady state and does not take into account the effects of turbulence or unsteady flow. Additionally, vector decomposition may not accurately represent the behavior of fluids with highly complex or chaotic motion.
  • Science and Math Textbooks
  • Differential Geometry
10K
