Simple Vector Question Related to Conservation of Momentum
In summary, the spaceship of mass M is traveling at a velocity of 20 km/s relative to the Sun. It ejects a rear stage of mass 0.2 M with a relative speed of 5 km/s. Using the conservation of momentum, the velocity of the ejected stage with respect to the Sun is U = vf - u, where vf is the velocity of the spaceship after ejection and u is the relative speed of the rear stage with respect to the spaceship. This is due to the fact that the relative velocity of the rear stage is opposite to the velocity of the spaceship.
SHISHKABOB
541
A spaceship of mass M is traveling in deep space with velocity vi = 20 km/s relative to the Sun. It ejects a rear stage of mass 0.2 M with a relative speed u = 5 km/s. What then is the velocity of the spaceship?
conservation of momentum, p = mv
let U be the velocity of the ejected rear stage and vf be the velocity of the ship after ejection.
pi = Mvi
pf = 0.2MU + 0.8Mvf
it's an example from the book and the next thing they do is say "The speed u of the ejected stage relative to the spaceship is the difference in velocities of the spaceship and stage"
u = vf - U
or
U = vf - ubasically, I am feeling really dumb for not understanding why u = vf - U. The example also states that the positive direction is in the direction of vi. If that's so, then shouldn't ube negative? I think I'm thinking about this too hard and have confused myself.
Relative velocity with respect to the spaceship can be understood as velocity relative to the final velocity vf. The relative speed of the rear stage with respect to the spaceship is u=5 m/s. The speed is positive, as it is the magnitude of velocity. The relative velocity of the rear stage is opposite to the velocity of the spaceship, so the relative velocity is vr=-u=-5 m/s.
The velocity of the rear stage with respect to the sun is U=vf+vr=vf-u.
ehild
FAQ: Simple Vector Question Related to Conservation of Momentum
What is conservation of momentum?
Conservation of momentum is a fundamental principle in physics that states that the total momentum of a system remains constant, unless acted upon by an external force. In simpler terms, it means that the total amount of motion in a system will not change unless there is an external force causing it.
How does conservation of momentum relate to vectors?
In the context of vector quantities, conservation of momentum means that the total vector sum of momentum in a system will remain constant. This is because momentum is a vector quantity, meaning it has both magnitude and direction. As long as the external forces acting on a system do not change, the total momentum in that system will remain constant.
Can you give an example of a simple vector question related to conservation of momentum?
A classic example of a simple vector question related to conservation of momentum is the "ballistic pendulum" experiment, where a projectile is fired into a pendulum and the resulting motion of the pendulum is observed. In this scenario, the initial momentum of the projectile is equal to the final momentum of the combined projectile and pendulum system, demonstrating conservation of momentum.
How is conservation of momentum used in real-world applications?
Conservation of momentum is a fundamental principle in physics and is used in various real-world applications, such as rocket propulsion, collisions in sports, and even in car safety features. It is also integral in understanding the motion of objects in space, such as planets and satellites.
Are there any exceptions to the law of conservation of momentum?
While the law of conservation of momentum is a fundamental principle in physics, there are some cases where it may not hold true. This can occur in extreme situations, such as at the subatomic level or in situations involving extremely high speeds or strong forces. However, in most everyday scenarios, conservation of momentum is a reliable principle to understand and predict the behavior of objects in motion.
