Simplfying Inverse Hyperbolic Cosine
In summary, the problem asks to simplify an expression involving arccosh and an interval of x values. The solution involves using the identity cosh(u) = 1/sqrt(1-tanh^2(u)), and solving for u using arctanh. By supposing that x is in the interval [0,1), we can simplify the expression to arctanh(x). Since arccosh is an even function, we can also write the solution as arctanh(|x|) over the interval (-1,1).
phyzz
35
Simplify the following expression:
[tex] arccosh \left(\frac{1}{\sqrt{1 - x^2}}\right) \forall x ∈ (-1, 1)[/tex]
[tex] cosh(u) = \left(\frac{1}{\sqrt{1 - tanh^{2}u}}\right) u ∈ ℝ [/tex]
[tex] x = tanhu ∴ u = arctanhx [/tex]
[tex] u ∈ (arctanh(-1), arctanh(1)) [/tex]
[tex] arccosh(coshu) = u = arctanhx [/tex]
but that gives me the interval with infinities in it which is what's confusing me.
I have the solution but I don't understand it particularly the first line.
4. Solution
Suppose that [tex] x ∈ [0, 1) [/tex] (Why are they supposing this?)
and that [tex] u = arctanhx ≥ 0 [/tex]
so
[tex] cosh(u) = \left(\frac{1}{\sqrt{1 - tanh^{2}u}}\right) = \frac{1}{\sqrt{1 - x^2}} [/tex] so therefore
[tex] arccosh \left(\frac{1}{\sqrt{1 - x^2}}\right) = arccosh(coshu) [/tex]
but [tex] arccosh(coshu) = u [/tex] as long as [tex] u ≥ 0 [/tex] which is the case here
From where [tex] arccosh \left(\frac{1}{\sqrt{1 - x^2}}\right) = u = arctanh(x) [/tex]
Since [tex] arccosh \left(\frac{1}{\sqrt{1 - x^2}}\right) [/tex] is an even function (another big ? here, don't know what an even function is) in [tex] x ∈ (-1, 1) [/tex] we obtain [tex] \forall x ∈ (-1, 1), arccosh \left(\frac{1}{\sqrt{1 - x^2}}\right) = arctanh(|x|) [/tex]
I appreciate the help!
Just as a hint for the last part, an even function is one such that f(-x) = f(x), meaning that the function is symmetric across the y-axis. If a function is even, that means we can solve for it over the interval (0, L) and we've implicitly solved it over (-L, L) since it is the same function on both sides of the axis.
Related to Simplfying Inverse Hyperbolic Cosine
1. What is the definition of inverse hyperbolic cosine?
The inverse hyperbolic cosine (acosh) of a number is the value whose hyperbolic cosine is equal to that number. It is written as acosh(x) = cosh^-1(x) = y, where x and y are real numbers.
2. What is the domain and range of the inverse hyperbolic cosine function?
The domain of the inverse hyperbolic cosine function is all real numbers greater than or equal to 1, and the range is all real numbers.
3. How is inverse hyperbolic cosine related to hyperbolic cosine?
Inverse hyperbolic cosine and hyperbolic cosine are inverse functions of each other, meaning that applying one function after the other will result in the original input. This relationship can be written as acosh(cosh(x)) = x and cosh(acosh(x)) = x.
4. What are some common simplifications for inverse hyperbolic cosine?
The most common simplifications for inverse hyperbolic cosine involve rewriting the function using logarithms. For example, acosh(x) can be rewritten as ln(x + sqrt(x^2 - 1)) or ln(x - sqrt(x^2 - 1)). Additionally, acosh(1) = 0 and acosh(e) = 1 are also commonly used simplifications.
5. How is inverse hyperbolic cosine used in real-world applications?
Inverse hyperbolic cosine has various applications in fields such as physics, engineering, and mathematics. It is commonly used to solve problems involving exponential growth or decay, as well as in the calculation of distances in hyperbolic geometry. It also has applications in statistics and probability, particularly in the analysis of normal distributions.
