Simplification of a complex exponential
In summary: For example, for n = 2, 3, 5, 7, 9, 11, 13, 15, 17, 19, 21, 23, 25, 27, 29, 31, 33, 35, 37, 39, 41, 43, 45, 47, 49, 51, 53, 55, 57, 59, 61, 63, 65, 67, 69, 71, 73, 75, 77, 79, 81, 83, 85, 87, 89, 91, 93, 95, 97, 99.In summary, the expression simplifies to:e^{j2x} = cos(x) + j sin(x)
fonz
151
Is there a way to simplify the following expression?
##[cos(\frac {n \pi} 2) - j sin(\frac {n \pi} 2)] + [cos(\frac {3n \pi} 2) - j sin(\frac {3n \pi} 2)]##
##e^{jx} = cos(x) + j sin(x)##
##cos(\frac {n \pi} 2)## and ##cos(\frac {3n \pi} 2)## produce the same result for all values of ##n##
Likewise, ##- j sin(\frac {n \pi} 2)## and ##- j sin(\frac {3n \pi} 2)## produce the same result for all values of ##n##
So if you know this (sure the sine formula is correct?), you can substitute the three folds of the angles by the simple angles. Next you wrote ##e^{jx} = \cos(x)+j\sin(x)##. Now what is ##e^{-jx}## and how are ##e^{jx}## and ##e^{-jx}## related? All these give you some simplifications. Whether they are those you're looking for depends on what you mean by simplification.
Likes fonz
Is ##n## supposed to be an integer?
BTW: don't write ##cos(x)##; write ##\cos(x)## instead. The first is ugly and hard to read, the second is pleasing and easy to read. To achieve this, just put a "\" in front of "sin", "cos", and most other standard functions---that is the way LaTeX was designed to be used. In other words, instead of using "sin", "cos", "tan", "log", "lim", etc., etc., use "\sin", "\cos', "\tan", "\og", "\lim", etc.
Likes fonz
Sorry I forgot to mention, ##n## is an integer. I am wonder if there is any way to simplify in this case?
Is there anything wrong with the following?
##[\cos(\frac {n \pi} 2) - j \sin(\frac {n \pi} 2)] + [\cos(\frac {3 n \pi} 2) - j \sin(\frac {3 n \pi} 2)] = 2[\cos(\frac {n \pi} 2) - j \sin(\frac {n \pi} 2)]##
What is ##\sin (\varphi + \pi)## and what if applied to ##\sin (\dfrac{3n\pi}{2})=\sin(\dfrac{n\pi}{2}+\pi)##?
##\sin(\varphi + \pi) = \sin(\varphi)##
##\sin(\frac {3n\pi} 2) = \sin(\frac {n\pi} 2)##
In which case my answer above should be correct.
Yes, in this case the answer would be correct. However, ##\sin (\varphi + \pi) = - \sin (\varphi)##, so you missed a minus sign. The result will still have a ##\cos (\dfrac{n\pi}{2})## term, which can be expressed as function of ##\cos (n\pi)## if you like.
Likes fonz
Very helpful thank you.
##\displaystyle \left [\cos\left(\frac {n \pi} 2\right) - j \sin\left(\frac {n \pi} 2\right) \right ] + \left[\cos\left(\frac {3n \pi} 2\right) - j \sin\left(\frac {3n \pi} 2\right) \right]##
##\displaystyle e^{jx} = \cos(x) + j \sin(x)##
I suggest using the exponent form to simplify this expression.
For particular values of integers n, you can put specific constants in for the sin and cos. So you can give a few cases that give the same constant value for each case.
Related to Simplification of a complex exponential
What is a complex exponential?
A complex exponential is a mathematical expression of the form ea+bi, where a and b are real numbers and i is the imaginary unit (√-1). It is a type of exponential function that involves both a real and an imaginary component.
Why is simplification of a complex exponential important?
Simplification of a complex exponential is important because it allows us to manipulate and solve complex exponential equations more easily. It also helps us to understand the behavior of complex exponential functions and their relationships to other mathematical concepts.
What is the process for simplifying a complex exponential?
The process for simplifying a complex exponential involves using the properties of exponents and logarithms to rewrite the expression in a simpler form. This may involve combining like terms, using the rules of exponentiation, or converting the expression into polar form.
When is a complex exponential considered fully simplified?
A complex exponential is considered fully simplified when it is written in the form A(cosθ + isinθ), where A is the amplitude or magnitude of the function, and θ is the phase angle or argument. In other words, all of the terms involving e (the base of the natural logarithm) have been eliminated.
What are some common mistakes to avoid when simplifying a complex exponential?
Some common mistakes to avoid when simplifying a complex exponential include forgetting to apply the rules of exponents and logarithms correctly, confusing the real and imaginary components, and failing to convert the expression into polar form when necessary. It is also important to be mindful of any restrictions on the values of a and b in the original expression.
