Try drawing a Venn diagram of ##B+\bar BA##. That should show you how to answer your question.momentum said:How can we write the below red marker boolean expression to simplify the equation?
Which Law is this?
B+!BA=B+A
Is this correct?
momentum said:B+!BA=B+A
Simplification of a Boolean expression is the process of reducing the expression to its simplest form by removing redundant or unnecessary terms and using Boolean algebra rules to combine terms.
Simplifying Boolean expressions can make them easier to understand and analyze, as well as reduce the number of terms and operations needed for evaluation. This can also help in minimizing the complexity of circuits in digital electronics.
Some common techniques include using Boolean algebra rules such as distributive, associative, and commutative laws, using De Morgan's laws, and applying the laws of Boolean identities and complements.
A Boolean expression is in its simplest form when it cannot be reduced any further, meaning all possible simplification techniques have been applied and no further simplification is possible.
No, simplifying a Boolean expression does not change its truth value. The simplified expression will have the same truth table and produce the same result as the original expression for all possible combinations of input values.
