Simplification of Trigonometric Expression
In summary, for small epsilon, the expression $\cos[k_n(L-\varepsilon)]-\cos k_nL$ can be simplified to $2\sin k_nL$. Using the trigonometric identity for $\cos[k_n(L-\varepsilon)]$, it becomes $\sim k_n \varepsilon\, \sin(k_n L)$. However, this is not true and taking a Mclaurin expansion of the first term gives the correct result of $\sin k_nL\sin k_n\varepsilon$.
Dustinsfl
2,281
I just read this for small epsilon this result can be further simpli ed by using the trigonometric identity for $\cos[k_n(L-\varepsilon)]$. Doing so result is
2\sin k_nL
I don't see this? Can someone explain?
Mathematics news on Phys.org
I just read this for small epsilon this result can be further simplied by using the trigonometric identity for $\cos[k_n(L-\varepsilon)]$. Doing so result is
2\sin k_nL
It's not true, it is \(\sim k_n \varepsilon\, \sin(k_n L)\)
CB
CB
What trig identity did you use though?
You can use the cosine of a sum formula, but you get the same result by taking a Taylor expansion of the first term.
CB
CaptainBlack said:
You can use the cosine of a sum formula, but you get the same result by taking a Mclaurin expansion of the first term.
CB
If we use cosine sum, shouldn't it be
\cos k_nL\underbrace{\cos k_n\varepsilon}_{\approx 1 \text{ for small }\varepsilon} + \sin k_nL\sin k_n\varepsilon - \cos k_nL = \sin k_nL\sin k_n\varepsilon
Recall $\displaystyle \sin\theta\approx\theta$ for small $\displaystyle \theta$.
FAQ: Simplification of Trigonometric Expression
What does it mean to simplify a trigonometric expression?
Simplifying a trigonometric expression means to manipulate the expression using trigonometric identities, properties, and rules to make it shorter and easier to evaluate.
Why is simplifying trigonometric expressions important?
Simplifying trigonometric expressions can help in solving complex problems, understanding relationships between different trigonometric functions, and making calculations more efficient.
What are some common trigonometric identities used in simplifying expressions?
Some common trigonometric identities used in simplifying expressions include the Pythagorean identities, quotient identities, reciprocal identities, and double angle identities.
Can all trigonometric expressions be simplified?
No, not all trigonometric expressions can be simplified. Some expressions may already be in their simplest form and others may have unique forms that cannot be simplified.
How do I know when a trigonometric expression is simplified?
A trigonometric expression is simplified when it cannot be further reduced using any of the trigonometric identities, properties, or rules.
