MHB Simplify (Adding and Subtracting Rational Functions)
The discussion focuses on simplifying the expression \(\frac{2x}{3y} - \frac{x^2}{4y^3} + \frac{3}{5y^4}\). Participants point out errors in the original simplification, particularly with the powers of \(y\) in both the numerator and denominator. A suggestion is made to use the lowest common denominator of \(60y^4\) for a more straightforward approach. The importance of checking for cancellation and ensuring accuracy in powers is emphasized. Correcting these mistakes will lead to a proper simplification of the rational function.
eleventhxhour
5c) Simplify.
$$\frac{2x}{3y} - \frac{x^2}{4y^3} + \frac{3}{5y^4} $$This is what I did, which is wrong according to the textbook. Could someone point out what I did wrong and how to correct it? Thanks.
$$\frac{(2x)(4y^3)-(x^2)(3y)}{(3y)(4y^3)} + \frac{3}{5y^4}$$
$$\frac{8xy^3-3x^2y}{(12y^3)} + \frac{3}{5y^4}$$
$$\frac{(8xy^3-3x^2y)(5y^4)+(3)(12y^4)}{(12y^3)(5y^4)}$$
$$\frac{(40xy^7-15x^2y^5)+36y^4}{60y^8}$$
Mathematics news on Phys.org
eleventhxhour said:
5c) Simplify.
Little things always mess you up.
Line 3, last term in the numerator. Check your power of y.
Last line, Check the power of y in the denominator.
Finally, there is some cancellation you can do.
-Dan
I would first observe that the lowest common denominator is $60y^4$ and to we may write the expression as:
$$\frac{2x}{3y}\cdot\frac{20y^3}{20y^3}-\frac{x^2}{4y^3}\cdot\frac{15y}{15y}+\frac{3}{5y^4}\cdot\frac{12}{12}$$
This is somewhat simpler than your method.
And so combining terms, what do we get?
As Dan stated, your expression is almost equivalent to this, you just need to divide each term in the numerator and denominator a common factor (after making the check Dan suggests).
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
