Simplify expression with exponents
In summary: Large {\dfrac{x^7}{3y^7}}}$In summary, the given expression can be simplified to $\dfrac{x^7}{3y^7}$ with positive exponents.
ahmedb
simplify and answer should be in positive exponents.
(((4x^6)^3(4y^-8))/((2x)^4(12y^3)^2))^1/2
please help and thanks
Mathematics news on Phys.org
Re: simplify
$$ \huge{(}\frac{{(4x^6)^3}4y^{-8}}{(2x)^4(12y^3)^2}\huge{)}^{\frac{1}{2}} $$
$$ \huge{(}\frac{{(4^3x^{18})}4y^{-8}}{(2^4x^4)(12^2y^6)}\huge{)}^{\frac{1}{2}} $$
$$ \huge{(}\frac{{(64x^{18})}4y^{-8}}{(16x^4)(144y^6)}\huge{)}^{\frac{1}{2}} $$
$$ \huge{(}\frac{4x^{14}}{36y^{14}}\huge{)}^{\frac{1}{2}} $$
$$ \huge{(}\frac{x^{14}}{9y^{14}}\huge{)}^{\frac{1}{2}} $$
$$ \huge{(}(\frac{x}{9y})^{14}\huge{)}^{\frac{1}{2}} $$
$$ (\frac{x}{9y})^{7} $$
Re: simplify
You should probably show any work you have tried first so that more importantly we can fix any misconceptions you may have about this process.
If your going any further in math the ability to do the work in this problem will be required.
You may now have the answer, but what you really need is the ability to reach it on your own.
Hello, MoneyKing!
$\text{Simplify: }\:\left[\dfrac{(4x^6)^3(4y^{-8})}{(2x)^4(12y^3)^2}\right]^{\frac{1}{2}}$
$\left[\dfrac{(4x^6)^3(4y^{-8})}{(2x)^4(12y^3)^2}\right]^{\frac{1}{2}} \;=\;\;\left[\dfrac{4^3(x^6)^3\cdot 4y^{-8}}{2^4x^4\cdot 12^2(y^3)^2}\right]^{\frac{1}{2}} \;=\;\;\left[\dfrac{64x^{18}\cdot 4y^{-8}}{16x^4\cdot144y^6}\right]^{\frac{1}{2}} $
. . . . . $=\;\;\left[\dfrac{x^{14}}{9y^{14}}\right]^{\frac{1}{2}} \;=\;\;
\dfrac{(x^{14})^{\frac{1}{2}}}{9^{\frac{1}{2}}(y^{14})^{\frac{1}{2}}} \;=\;\;\dfrac{x^7}{3y^7} $
To simplify this expression, we can use the rules of exponents to rewrite the terms with negative exponents as fractions with positive exponents in the denominator. This will result in:
(((4x^6)^3(4/y^8))/((2x)^4(12/y^3)^2))^1/2
Next, we can use the power rule of exponents to simplify the terms inside the parentheses. This will result in:
(((64x^18)(4/y^8))/((16x^4)(144/y^6)))^1/2
We can then combine like terms in the numerator and denominator to get:
((256x^18)/(2304x^4y^14))^1/2
Next, we can use the quotient rule of exponents to simplify the fraction. This will result in:
(256/2304)(x^18/x^4)(y^-14)^1/2
Using the power rule of exponents again, we can simplify the terms inside the parentheses to get:
(1/9)(x^14)(1/y^7)
Finally, we can rewrite the expression with positive exponents to get the simplified form:
x^14/(9y^7)
Therefore, the simplified expression with positive exponents is x^14/(9y^7).
FAQ: Simplify expression with exponents
What is an exponent?
An exponent is a mathematical notation that indicates the number of times a base number should be multiplied by itself.
How do you simplify an expression with exponents?
To simplify an expression with exponents, you can use the laws of exponents. These include rules for multiplying, dividing, and raising exponents to a power.
Can you give an example of simplifying an expression with exponents?
Sure, for example, the expression 5^4 can be simplified to 625 by multiplying 5 four times: 5 x 5 x 5 x 5 = 625.
What is the difference between exponents and powers?
In mathematics, exponents and powers are essentially the same thing. However, exponents are typically written in superscript form, while powers are written with the base number and exponent separated by a caret (^) symbol.
Are there any special cases to consider when simplifying expressions with exponents?
Yes, there are a few special cases to keep in mind when simplifying expressions with exponents. These include negative exponents, zero as an exponent, and fractional exponents.
