Simplifying a Legendre polynomial
In summary, the conversation discusses the expression $\mathcal{P}_n(0)$ and its simplification to $\frac{1}{2^n n!}\binom{n}{\frac{n}{2}}n!(-1)^{\frac{n}{2}}$ when $k$ is even. The key point is the computation of $\frac{d(x^p)}{dx^q}$, which simplifies to $0$ when $q>p$ and $p!$ when $p<q$. The final result is given as $\frac{(-1)^{\frac{n-1}{2}}}{2^{n-1}}\frac{(n-1)!}{\left(\frac{n-1}{
Dustinsfl
2,281
Given the following expression
\mathcal{P}_{n}(0) = \left.\frac{1}{2^{n}n!}\frac{d^{n}}{dx^{n}}
\sum_{k = 0}^{n}\binom{n}{k}(x^2)^k(-1)^{n - k}\right|_{x = 0},
\qquad (*)
I know for \(k\) even we get
\mathcal{P}_{n}(0) = \frac{1}{2^{n}n!}\binom{n}{\frac{n}{2}}n!(-1)^{n / 2}.
\qquad (**)
However, I don't see how this is done. Can someone explain how we go from \((*)\) to \((**)\)?
The key point is the computation of $\frac{d(x^p)}{dx^q}$: if $q>p$ this is $0$, if $p<q$ this gives, evaluated at $0$, again $0$. And the $p$-th derivative of $x^p$ is $p!$.
How does this simplify?
\begin{align*}
I_{n} &= \frac{1}{2n + 1}\left[\frac{1}{2^{n - 1}}
\binom{n - 1}{\frac{n - 1}{2}}(-1)^{(n - 1)/2} -
\frac{1}{2^{n + 1}}
\binom{n + 1}{\frac{n + 1}{2}}(-1)^{(n + 1)/2}\right]\\
&= \frac{1}{(2n + 1)2^{n - 1}\left[\left(\frac{n - 1}{2}\right)!\right]^2} \left[(n-1)!(-1)^ {(n - 1)/2} - \frac{4}{n^2}(-1)^{(n + 1)/2}\right]\\
&= \frac{(-1)^{(n - 1)/2}}{2^{n - 1}}\frac{(n - 1)!}{
\left(\frac{n - 1}{2}\right)!\left(\frac{n - 1}{2}\right)!}
\frac{1}{n + 1}
\end{align*}
FAQ: Simplifying a Legendre polynomial
What is a Legendre polynomial?
A Legendre polynomial is a type of mathematical function used in physics and engineering to represent certain physical systems, such as the electric potential of a charged sphere or the angular distribution of particles in a quantum system. They are named after the French mathematician Adrien-Marie Legendre who first studied them in the late 18th century.
Why do we need to simplify a Legendre polynomial?
Legendre polynomials can become quite complex and difficult to work with, especially when dealing with higher order polynomials. Simplifying them makes calculations and analysis much easier and more efficient.
How do you simplify a Legendre polynomial?
The simplification of a Legendre polynomial involves using mathematical techniques such as integration, differentiation, and substitution to reduce the polynomial to its simplest form. This often involves finding roots and using orthogonality properties of the polynomials.
What are the benefits of simplifying a Legendre polynomial?
Aside from making calculations easier, simplifying a Legendre polynomial can also reveal important patterns and relationships between different polynomials. This can lead to a better understanding of the underlying physical system and can help in making predictions and solving problems.
Are there any limitations to simplifying a Legendre polynomial?
While simplifying a Legendre polynomial can be useful, it is important to note that the simplified form may not be an exact representation of the original polynomial. This is due to the use of approximation techniques and the loss of certain information during the simplification process. Therefore, it is important to consider the limitations and potential errors when using simplified Legendre polynomials in calculations or analysis.
