Simplifying a square root expression
In summary, the given expression is simplified by substituting a value for $x$ and checking if the original expression is equal to the simplified version. However, unless the domain of $x$ is known to be non-negative, the correct simplification should include the use of absolute value. There may also have been a typo in the textbook's simplification.
tmt1
234
I have this expression:
$$\sqrt{ 1 - \frac{16}{\sqrt{x^2 + 16}}}$$
And the textbook simplifies it to
$$\frac{x}{\sqrt{x^2 + 16}}$$
But I'm not sure how it does this.
Mathematics news on Phys.org
I can see the following being true:
\(\displaystyle \sqrt{1-\frac{16}{x^2+16}}=\frac{|x|}{\sqrt{x^2+16}}\)
But what you say your textbook is implying is not true.
Suggestions (in general):
1: during simplification process, let k = SQRT(x^2 + 16);
saves significant "time"
2: substitute a value for x: then check if original
expression = book's expression
Write:
$\sqrt{ 1 - \dfrac{16}{\sqrt{x^2 + 16}}} = \sqrt{\dfrac{x^2 + 16}{x^2 + 16} - \dfrac{16}{x^2 + 16}}$
and simplify the numerator under the radical.
As MarkFL implies, unless the domain of $x$ is known to be non-negative, we have:
$\sqrt{x^2} = |x|$, not $x$.
Deveno said:
Write:
but this is clearly not true.
Looks to me like a ye olde typo, nuttin' else !
Indeed, I missed an extra radical in the denominator, leaving me to wonder what the text in question actually says...
FAQ: Simplifying a square root expression
What does it mean to simplify a square root expression?
Simplifying a square root expression means to rewrite it in its simplest form by factoring out perfect square numbers and removing any unnecessary symbols or terms.
Why is it important to simplify a square root expression?
Simplifying a square root expression makes it easier to work with in mathematical calculations and can help identify any patterns or relationships within the expression.
What are the steps for simplifying a square root expression?
The steps for simplifying a square root expression are:
1. Identify any perfect square factors in the radicand (number under the radical symbol).
2. Take the square root of the perfect square factors.
3. Multiply the square roots together.
4. Simplify any remaining radicals.
5. Combine any like terms outside the radical symbol.
Can a negative number be simplified in a square root expression?
Yes, a negative number can be simplified in a square root expression. However, the answer will result in an imaginary number (a number multiplied by the imaginary unit, i).
How can simplifying a square root expression be useful in real-life situations?
Simplifying a square root expression can be useful in solving real-life problems involving distance, areas, and volumes. It can also be used in fields such as engineering, physics, and finance to simplify complex equations and make them easier to analyze and interpret.
