Simplifying an expression using limits
In summary: The limit is such that a tends to zero while V tends to infinity at the same time, so the limit of the term V^2 \sinh^{2}(ka) cannot be done simply by setting a = 0 as you've done. A good starting point is to Taylor expand \sinh^{2}(ka), and see where that gets you to, before taking the limits.In summary, the limits for the sinh^2(x) function when a is large but not infinite are as follows: when a is large, the limit is written as \sinh^2(x) \sim e^{2x}/4, and when a tends to zero and the potential tends to infinity,
whatisreality
290
Given that
##T = \frac{4E(V-E)}{4E(V-E)+V^2\sinh^2 (ka)}##
Simplify the expression for T when a is large but not infinite, and again for the case when a tends to zero and the potential tends to infinity, such that ##d = Va## is a real constant. k is a constant, as is E (which is assumed to be less than V).
To try and simplify it for the first case, I used the exponential definition of sinh, squared it and got that
##\sinh^2(x) = \frac{1}{4}(e^{2x}+e^{-2x}-2)##
For large x the ##e^{-2x}## term would get small very quickly, especially compared to the other exponential term which would increase rapidly. So this becomes
##\sinh^2(x) = \frac{1}{4}(e^{2x}-2)##
I don't know if that's what the question meant. It doesn't seem massively simpler. Is there something else that can be done to simplify the expression?
And the second part, I don't know where to start! There should be some sort of constant ##d = Va##, but I thought ##sinh^2(0)=0##, which would mean that ##a## disappears. As far as I can see that expression simplifies to 1 for the second set of limits! Why is that wrong?
What is the dominating term in the denominator?
The limit is such that a tends to zero while V tends to infinity at the same time, so the limit of the term [itex]V^2 \sinh^{2}(ka)[/itex] cannot be done simply by setting a = 0 as you've done. A good starting point is to Taylor expand [itex]\sinh^{2}(ka)[/itex], and see where that gets you to, before taking the limits.
whatisreality said:
Given that
Even better in the large-##a## case would be to write ##\sinh^2(x) \sim e^{2x}/4##, because ##e^{2x}## is overwhelmingly large compared to the 2. Also, if ##E(E-V)## remains constant, it is overwhelmingly small compared with the second term in the denominator, and that leads to even more simplification.
It would help to note that
$$k^2 = \frac{2m(V-E)}{\hbar^2}.$$ Since ##ka## depends on both ##a## and ##V##, you need to first figure out how it behaves in the limit as ##a \to 0## and ##V \to \infty## before writing down an approximation for ##\sinh ka##. Start by writing ##V = d/a## and getting everything in terms of ##a##.
Oh, I completely forgot about that! Thanks, I'll rewrite in terms of ##a## now.
In terms of a, ##ka = \frac{\sqrt{2mad - 2ma^2E}}{\hbar}##.
That still tends to zero, given d is a real constant. So ##sinh^2(ka)## tends to zero, since its taylor expansion is ##x^2 + \frac{x^4}{3} + \frac{2x^6}{45}##.
Taking the ##V^2## term into account, how do I know what happens? I've never dealt with composite limits before, it kind of looks like V tends to infinity just as fast as the ##sinh^2## term tends to zero!
Sorry, misplaced # in the post above.
Is getting everything in terms of a equivalent to getting it in terms of V, or do both cases have to be considered?
Why not try multiplying [itex]V^{2}[/itex] to your Taylor series expansion and see what you get? There'll be some simplifications that allow you to take the limit properly.
[Hint: use Va = d]
Related to Simplifying an expression using limits
What is the definition of a limit when simplifying an expression?
A limit is a fundamental concept in calculus that represents the value that a function approaches as its input approaches a certain value or point.
How do you use a limit to simplify an algebraic expression?
To simplify an expression using limits, you first need to identify the variable that is approaching a certain value. Then, you can use algebraic techniques such as factoring, canceling out common factors, or applying rules of exponents to simplify the expression.
What are the common types of limits used in simplifying expressions?
The most common types of limits used in simplifying expressions are the limits at infinity, where the input value approaches positive or negative infinity, and the limits at a specific point, where the input value approaches a fixed number.
Can using limits to simplify an expression always give an exact value?
No, using limits to simplify an expression does not always give an exact value. In some cases, the simplified expression may involve indeterminate forms, such as 0/0 or infinity/infinity, which require further evaluation using other techniques.
What are the benefits of using limits to simplify an expression?
Using limits to simplify an expression allows us to evaluate the behavior of a function at a specific point or as the input value approaches infinity. This can provide insights into the overall behavior of the function and help us solve complex problems in calculus and other areas of mathematics.
