MHB Simplifying expression with exponents
The expression $(-4x^n)$ simplifies to $(-4)^n \cdot x^n$ because the negative sign only applies to the coefficient, not the variable. In contrast, if the expression were $(-4x)^n$, it would equal $(-4)^n \cdot x^n$ or $4^n \cdot (-x)^n$. The discussion clarifies that $-4 \cdot -x$ results in $4x$, not $-4x$. Therefore, the correct interpretation hinges on the placement of parentheses and the application of the negative sign. Understanding these nuances is essential for accurate simplification of expressions involving exponents.
tmt1
Supposing I have
$$(-4x^n)$$
Why does it equal $(-4)^n * x^n$ and not $(-4)^n * (-x) ^ n$?
When we have a negative symbol it only applies to the first item in an expression? so $-xbcw$ equals $b * c * w * (-x)$? Which means if we wanted the other items to be negative we would have to do $x(-b)(-c)w$ (for $b$ and $c$ to be negative and the other items to be positive)?
Mathematics news on Phys.org
Essentially you have $-4x^n$ which is equal to $-4\cdot x^n$.
If you intended $(-4x)^n$ then we have $(-4x)^n=(-4)^n\cdot x^n$ or $4^n\cdot (-x)^n$.
$-4\cdot-x=4x$ not $-4x$.
Does that help?
Does that help?
So, in no uncertain terms, $(-4)^n\cdot x^n$ equals $4^n\cdot (-x)^n$ ?
Yes.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
