MHB Simplifying Logical Expressions [SOLVED]
The discussion focuses on simplifying logical expressions using DeMorgan's Law and the Distributive Property. The original expression, NOT(a < 20 AND (b < 10 OR b > 10)), is simplified correctly to a >= 20 OR b = 10 after applying DeMorgan's Law twice. Participants debate the meaning of "simplifying an expression," noting that simplification can vary based on the number of connectives and clarity of the expression. It is emphasized that while the number of connectives may decrease, the overall complexity can remain similar. Ultimately, the conversation highlights the subjective nature of simplification in logical expressions.
Valtham
[SOLVED] Simplifying Expressions
Hello all I am a bit confused about the laws I am learning about right now and attempted some of my own exercises to understand them a bit.
I have the problem NOT(a < 20 AND (b < 10 OR b > 10)) and I need to simplify it.
From my understanding I can use DeMorgan's Law which then gives me the expression NOT a < 20 OR NOT(b < 10 OR b > 10). I can then use the Distributive Property to create the expression (NOT a < 20 OR NOT b < 10) AND (NOT a < 20 OR NOT b > 10).
What I am confused about is after I use DeMorgan's Law the first time is it correct to use the Distributive Law next? Or should I have used DeMorgan's Law again?
You can't use the distributive law immediately after the first De Morgan's law. Distributivity requires that the expression has both a disjunction and a conjunction. So, first you need to convert NOT(b < 10 OR b > 10) into (NOT b < 10) AND (NOT b > 10) and then use distributivity. You indeed get (NOT a < 20 OR NOT b < 10) AND (NOT a < 20 OR NOT b > 10).
If < denoted the regular order, then I believe the simplest form of this is expression is a >= 20 OR b = 10.
Thanks for the reply. Makes total sense that I would have to use DeMorgan's Law again. I can see how you get a >= 20 OR b = 10, but what if the expression had been (NOT a < 20 AND NOT (b <= 10 OR b >= 15)). Using that expression the "simplified" version would be a >= 20 OR b >= 10 AND b <= 15. To me that expression hardly seems simplified, and all we did was remove the "NOT" connectives pretty much. What does "simplifying an expression" mean exactly? We weren't really given a precise definition other than an example that removes as many variables and connectives as possible.
It should say, "... b > 10 AND b < 15." Also, usually AND is considered to have higher priority than OR, so omitting parentheses is OK, but unless this is an explicit convention in your course, it may still make sense to put parentheses around b > 10 AND b < 15 to remove any ambiguity.
There are different measures with respect to which simplification can be defined. Here the answer has 2 connectives vs 4 in the original expression, so in this sense it is simpler. On the other hand, the number of atomic propositions is the same. Informally, for me it is a little easier to understand a >= 20 than NOT a < 20. Also, b > 10 AND b < 15 is often abbreviated as 10 < b < 15, which makes it even simpler.
I'm taking a look at intuitionistic propositional logic (IPL). Basically it exclude Double Negation Elimination (DNE) from the set of axiom schemas replacing it with Ex falso quodlibet: ⊥ → p for any proposition p (including both atomic and composite propositions). In IPL, for instance, the Law of Excluded Middle (LEM) p ∨ ¬p is no longer a theorem. My question: aside from the logic formal perspective, is IPL supposed to model/address some specific "kind of world" ? Thanks.
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
