Simplifying roots of negative numbers
In summary, the Khan Academy video discusses the concept of breaking the square root of a product into the product of two square roots, under certain conditions. It is stated that this is only valid when both numbers are non-negative, or when one is negative and the other is positive. The explanation for this rule is that when working with complex numbers, there are always two numbers that can produce the same result when squared. The video also mentions that the decision to define the square root as either positive or having a positive imaginary part is somewhat arbitrary and may not work with general complex numbers. A recommended resource for further understanding of complex numbers is provided.
maxverywell
197
In this Khan Academy video
they say that it is ok to break the square root ##\sqrt{a\cdot b}##, with ##a, b \in \mathbb{R}##, into the product of two square roots ##\sqrt{a}\cdot \sqrt{b}##, only when: (1) both are non negative, (2) one of the two is negative and the other is possitive. I know that (1) is true by definition of the square root, but is (2) true? If (2) is true then what is the explanation for why a and b cannot be both negative?
Mathematics news on Phys.org
If you work with complex numbers, for every x there are always two numbers that produce x when squared. Which one do you define as square root? You can arbitrarily pick one. That leads to rules like (1) and (2), where you decide that the square root of a positive number should be positive and the square root of a negative number should have a positive imaginary part. That decision is somewhat arbitrary, and doesn't work if you go to general complex numbers.
Likes maxverywell
Related to Simplifying roots of negative numbers
1. How do you simplify roots of negative numbers?
The first step in simplifying roots of negative numbers is to rewrite the negative number as its complex conjugate. This means changing the sign of the imaginary part of the number. Then, you can use the rules of simplifying radicals to simplify the expression.
2. Can you simplify the square root of a negative number?
No, the square root of a negative number is not a real number. It is an imaginary number. However, you can simplify the square root of a negative number by following the steps mentioned in the first question.
3. Why do we need to simplify roots of negative numbers?
Simplifying roots of negative numbers allows us to express complex numbers in a simplified form, making it easier to work with them in mathematical calculations.
4. Are there any special rules for simplifying roots of negative numbers?
Yes, there are some special rules that apply only to simplifying roots of negative numbers. For example, when simplifying the cube root of a negative number, you need to remember to include the absolute value of the number inside the radical.
5. Can you simplify higher order roots of negative numbers?
Yes, you can simplify higher order roots of negative numbers by following the same steps as simplifying square roots. Rewrite the negative number as its complex conjugate and then simplify the expression using the rules of simplifying radicals.
  • General Math
  • General Math
  • General Math
