MHB Simplifying with square roots?
The discussion focuses on simplifying the expression 3√((10x^3)² / (10x^6)⁻¹). The simplification process involves rewriting the expression as (10x^3)² multiplied by (10x^6)¹, resulting in 10³x¹². Applying the cube root to 10³x¹² yields (10³)^(1/3) and (x¹²)^(1/3), which simplifies to 10x⁴. The final simplified result is 10x⁴.
arroww
So, this is probably really simple...but I keep getting the wrong answer when trying to simplify this:
$$3\sqrt{\frac{(10x^3)^2}{(10x^6)^{-1}}}$$Could someone show the steps to simplifying it? Thanks so much. (:
Mathematics news on Phys.org
Hello, arroww!
\sqrt[3]{\frac{(10x^3)^2}{(10x^6)^{\text{-}1}}}
Under the cube root, we have:
.\frac{(10x^3)^2}{(10x^6)^{\text{-}1}} \;=\; (10x^3)^2(10x^6)^1
. . . =\;10^2\cdot x^6\cdot 10\cdot x^6 \;=\;10^3x^{12}
Then: .\sqrt[3]{10^3x^{12}} \;=\;\left(10^3x^{12}\right)^{\frac{1}{3}}
. . . =\;\left(10^3\right)^{\frac{1}{3}}\left(x^{12} \right)^{\frac{1}{3}} \;=\;10x^4
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
